  3. failed to generate netlist of nport model in adexl
  • Views 17854
Karev11
Karev11 over 10 years ago
My test bench has nport model which points to a s-parameter file. I have no problem running sims in ADEL. however, when I tried to run it in ADEXL, I kept getting netlist error messages as below, basically it complains about every terminal in the nport model being "unbound".  "check-and-save" as it suggested didn't help, restart cadence didn't help.
Do you happen to know what could cause that?
thanks,
Kev
\o Begin Incremental Netlisting Mar 17 03:20:36 2016
\o ERROR (OSSHNL-903): Failed to generate a netlist because terminal 'm3' of instance 'I3' in cellview
\o '     zz/zz_test_tb/schematic' is unbound. Do Check and Save for a schematic cellview, and for
\o other views, check and fix the design before trying to generate the netlist
\o ERROR (OSSHNL-903): Failed to generate a netlist because terminal 'p3' of instance 'I3' in cellview
\o 'zz/zz_test_tb/schematic' is unbound. Do Check and Save for a schematic cellview, and for
    Kev,
    This sounds very strange. I think I'd need to see the testcase to understand what's going on. Can you report this to customer support? Then we could have a web sharing session where we can take a look.
  • Karev11
    Thanks Andrew,  I'll try that through our CAD team.
    Another question, is there a way in ADEL to export output values to a file? I tried to at Output section and expression editor  section (in calculator), they allow you to export the expressions of output to a file but not the output values.
    I know it's very easy to do at ADEXL.
    Sorry this may sound a change of subject, but i was just trying get data out to a file from a testbench that has nport model..
    No, sorry. You could save the ADE L setup to an OCEAN script and then adapt that so that it wrote all the outputs into a file, maybe.
