  3. Liberate: Unable to characterize sequential cells for subthreshold...
  • Subscribers 136
  • Views 20168
Liberate: Unable to characterize sequential cells for subthreshold operation
marten
marten over 10 years ago
Hi there,
I am working with a 28nm PDK and want to characterize a D-FlipFlop and a D-Latch for voltages at 300mV and below.
Liberate is not able to calculate / estimate the constraints for the cells and throws this kind of errors:
ERROR (LIB-52): On arc 'DF_X1 CLK r D r setup_rising rise_constraint', the constraint search failed to find a solution within the search range. The cell will be marked as failed and the .lib will contain 'constraint_failed_value'.  To debug, save and review the simulation results using extsim_save_passed and extsim_save_failed. Possible causes include: constraint_delay_degrade too large; constraint_delay_degrade_abstol too large; constraint_search_bound too small. Modify the constraint parameters and rerun.
ERROR (LIB-52): On arc 'DF_X1 CLK r D f setup_rising fall_constraint', the constraint search failed to find a solution within the search range. The cell will be marked as failed and the .lib will contain 'constraint_failed_value'.  To debug, save and review the simulation results using extsim_save_passed and extsim_save_failed. Possible causes include: constraint_delay_degrade too large; constraint_delay_degrade_abstol too large; constraint_search_bound too small. Modify the constraint parameters and rerun.
ERROR (LIB-52): On arc 'DF_X1 CLK r D r hold_rising rise_constraint', the constraint search failed to find a solution within the search range. The cell will be marked as failed and the .lib will contain 'constraint_failed_value'.  To debug, save and review the simulation results using extsim_save_passed and extsim_save_failed. Possible causes include: constraint_delay_degrade too large; constraint_delay_degrade_abstol too large; constraint_search_bound too small. Modify the constraint parameters and rerun.
ERROR (LIB-52): On arc 'DF_X1 CLK r D f hold_rising fall_constraint', the constraint search failed to find a solution within the search range. The cell will be marked as failed and the .lib will contain 'constraint_failed_value'.  To debug, save and review the simulation results using extsim_save_passed and extsim_save_failed. Possible causes include: constraint_delay_degrade too large; constraint_delay_degrade_abstol too large; constraint_search_bound too small. Modify the constraint parameters and rerun.
ERROR (LIB-52): On arc 'DF_X1 CLK f falling_edge min_pulse_width_low', the constraint search failed to find a solution within the search range. The cell will be marked as failed and the .lib will contain 'constraint_failed_value'.  To debug, save and review the simulation results using extsim_save_passed and extsim_save_failed. Possible causes include: constraint_search_bound too small. Modify the constraint parameters and rerun.
I played with the parameters
constraint_search_bound 1e-6
constraint_search_bound_estimation_mode 3
But it did not work. Below you can find my char.tcl script and the corner.tcl file.I would be really happy about any hint from the more experienced liberat users.
Cheers,
Marten
char.tcl:
# Liberate control file
set rundir .
set cornerf [split  0.3_0.3_0_0_25 "_"]
lassign $cornerf vddVoltage vddsVoltage gndVoltage gndsVoltage temp
exec mkdir -p ${rundir}/ldb
exec mkdir -p ${rundir}/lib
exec mkdir -p ${rundir}/VITAL
exec mkdir -p ${rundir}/datasheet
source ${rundir}/corner.tcl
#set spicefiles /netlist/.scs
set_var extsim_model_include "$env(GIT_LIBDIR)/corners.scs"
#set_var extsim_deck_include 1
#set_var extsim_exclusive 0
#set_var sim_estimate_duration 0
#set_var sim_duration 1
set_var constraint_search_bound_estimation_mode 3
set_var constraint_search_bound 1e-6
set_var spectre_use_char_opt_license 1
#Save external sim files / log for failed cells. Options: none, deck, all, all_plus_em_reports
set_var extsim_save_failed all
#set_var extsim_leakage_option "accurate=1 brief=1 runlvl=6 method=gear gmindc=1e-15 gmin=1e-15 kcltest=1"
set_var extsim_option "accurate=1 brief=1 runlvl=6 autostop gmindc=1e-15 gmin=1e-15"
define_leafcell -extsim_model -type nmos -pin_position {0 1 2 3} {nfet}
define_leafcell -extsim_model -type pmos -pin_position {0 1 2 3} {pfet}
define_leafcell -extsim_model -type nmos -pin_position {0 1 2 3} {lvtnfet}
define_leafcell -extsim_model -type pmos -pin_position {0 1 2 3} {lvtpfet}
define_leafcell -extsim_model -type diode -pin_position {0 1} {diodenwx}
## When a combined cell subckt-file is used
foreach cell $cells {
    lappend spicefiles ${rundir}/NETLIST/${cell}.scs
#read_spice -format {spectre} $spicefiles
read_spice -format {hspice} liberate.spi
## Characterize the library for NLDM (default), CCS and ECSM timing.
char_library -ecsm -ccsn -ccsp -extsim Spectre -cells ${cells}
## Save characterization database for post-processing ##
write_ldb ${rundir}/ldb/CORE_${vddVoltage}_${vddsVoltage}_${gndVoltage}_${gndsVoltage}_${temp}.ldb
## Generate a .lib with ccs, ecsm LOCAL ###
write_library -overwrite -ecsm ${rundir}/lib/SUBVT28CORE_${vddVoltage}_${vddsVoltage}_${gndVoltage}_${gndsVoltage}_${temp}_ecsm.lib
write_library -overwrite -ccs  ${rundir}/lib/SUBVT28CORE_${vddVoltage}_${vddsVoltage}_${gndVoltage}_${gndsVoltage}_${temp}_ccs.lib
## Generate ascii datatsheet ###
write_datasheet -format text ${rundir}/datasheet/SUBVT28CORE
corner.tcl:
set_operating_condition -voltage $vddVoltage -temp $temp
set_vdd vdd! $vddVoltage
set_vdd vdd $vddVoltage
set_vdd vdds! $vddsVoltage
set_vdd vdds $vddsVoltage
set_gnd gnd! $gndVoltage
set_gnd gnd $gndVoltage
set_gnd gnds! $gndsVoltage
set_gnd gnds $gndsVoltage
set_var slew_lower_rise 0.3
set_var slew_upper_rise 0.7
set_var slew_lower_fall 0.3
set_var slew_upper_fall 0.7
set_var measure_slew_lower_rise 0.3
set_var measure_slew_upper_rise 0.7
set_var measure_slew_lower_fall 0.3
set_var measure_slew_upper_fall 0.7
#set_var max_transition 1.5e-06
set cells {  DL_X1 DF_X1 }
define_template -type delay -index_1        {150 300 450} -index_2        {0.0150 0.0500 0.1500} delay_template_3x3
define_template -type power -index_1        {150 300 450} -index_2        {0.0150 0.0500 0.1500} power_template_3x3
define_template -type constraint -index_1  {1001 1002 1003} -index_2  {1001 1002 1003} constraint_template_3x3
set inputs  {A B C D S}
set outputs {Z Q}
set clocks  {CLK}
set async  {STN RST}
define_cell -input $inputs  -output $outputs -clock $clocks -constraint  constraint_template_3x3 -delay       delay_template_3x3 -power       power_template_3x3 $cells
  • Quek
    Quek over 10 years ago
    Hi Marten
    If you have already tried Liberate 15.1 and is still encountering the same LIB-52 error, it would be good for you to file a case to your local Cadence support. It may be a bug.
    Best regards
    Quek
  • fengye
    fengye over 7 years ago
    Hello! From the question, I know you must know much about Cadence Liberate。I want to learn how the liberate calculates the internal switching power and hidden power. Because the power uint is pJ, but I don't understand the time for calculating power. This operation may be relative with "sim_duration","sim_estimate_duration". But I don't understand it. Can you explain that? Thank you very much!
  • Quek
    Quek over 7 years ago in reply to fengye
    Hi Fengye
    Just a gentle reminder not to append to old threads. This thread has already ended 3 years ago. It is better for you to start a new thread so that we can focus on only your issue and not be distracted by past issues.
    Best regards
    Quek
  • fengye
    fengye over 7 years ago in reply to Quek
    Thanks for your reminder. I have put my new problems. But I still don't have any reply. Hope someone can help me.
    Best regards
    Andrew Beckett over 7 years ago in reply to fengye
    You asked the question in thread https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/40759/cadence-liberate-used-for-standard-cells-characterization only 5 hours ago. These forums are not intended to be the main support channel for Cadence tools (that's via customer support). Urgent questions should be asked via customer support, as the community forums are answered by both Cadence people and other community users in their spare time. I'm sure Guangjun in my team will answer your other question, but he's almost certainly busy right now...
  • fengye
    fengye over 7 years ago in reply to Andrew Beckett
    Thanks a lot ! This is my first time to propose my problem in this platform. I don't know much about the notice. You said your team can answer my question ,but he is so busy. I hope can get his help when he is in  his spare time.
    Thanks again!
    Best regards !
    fengye
