  3. Regarding monte carlo simulations
  • Replies 7
  • Views 22862
ag2888
ag2888 over 10 years ago
I am trying to run monte carlo simulations for my design and see the following trends in it.
The results vary if i add in a circuit which is not connected to the circuit for which the result is being considered.
The results vary even if i add in dummy devices, resistors etc.
If i manually choose the added devices to be ignored, only then the result remains the same.
Is this expected for the monte carlo sims?
    Andrew Beckett over 10 years ago +2
    Monte Carlo is very simple. The model files describe a set of parameters (which are used within the models) which have a described statistical variation. For example, they specify the standard deviation…
    I assume by "vary", you mean you don't get exactly the same results as without the devices. The variation of all devices should still be within the distribution for parameters, but they are unlikely to be precisely the same run to run if you add additional devices and have mismatch enabled.
    The reason for this is that mismatch parameters are generated by the random number generator for each subckt instance in the circuit. This means that if  you have a different number of devices, this will alter the sequence of the random number generator and so it won't be the same as it was the previous time. If you tell Monte Carlo that mismatch is not to be applied for a set of devices, then the random number generator doesn't get called for those devices and that's why you see the results the same from run to run, even if you add the extra devices.
    So yes, this is expected (if I've understood what you're saying). Generally speaking it shouldn't matter because the results are still within the distributions of the random variables.
  • ag2888
    Yes i meant the results are different when the additional devices are added in.
    But isn't this incorrect as this would mean we would have different results at every hierarchy. Then which result should we be considering? Also then at the top level even unrelated blocks will affect the results for every block?
    As an example, i saw the below results for the tests that i ran on 2 unrelated res divider circuits-
    Res div A and res div B have no connection to each other at all except they share the same ground.
    Initial MC run results (1 sigma) were : A output=1.39mV & B output=532uV
    But when I add 20 pieces of dummy resistors on res div B,1 sigma results were: A output=1.29mV & B output=2.74mV
    Also wanted to clarify one thing, what exactly do you mean by - the results are still within the distribution of the parameters?
    Does it mean that results are still valid results as the random values for device parameters are chosen from the defined distribution data for the same?
  • ag2888
    Also for the above example the spec on the res divider output is tight as variation of  a few mV in this will result in a large variation at final output due to the gain.
  • ag2888
    Just wanted to seek some clarification for this behaviour during monte carlo sims.
    Monte Carlo is very simple. The model files describe a set of parameters (which are used within the models) which have a described statistical variation. For example, they specify the standard deviation for process variation, and also for mismatch variation. The process variation is applied globally to the circuit, whereas mismatch variation is per-instance (actually per-subckt-instance, but that's a minor point).
    When Monte Carlo with mismatch (or all) is run, the dice is rolled for each subckt instance in the design, generating a value for each mismatch parameter, conforming to the distribution specified for that parameter. This is done for each "sample" in the Monte Carlo run.
    Because of this, the precise results for any iteration (i.e. any sample) will be dependent upon the number of instances there are. Similarly it's dependent upon the seed that is used to start the random number generator (in ADE XL this is normally defaulted to 12345 but can be changed). A specific sample has no physical meaning - it's just one sample out of the entire distribution of all of the random parameters. So you should never get too hung up on any specific result. What matters is the overall distribution of a sufficiently large number of samples.
    I don't know how many monte carlo points (or samples) you did in your run, but I suspect it was too small if you're getting that amount of variation in your sigma. There are options in ADE XL to plot the Standard Deviation versus the number of iterations - if you click on the drop-down on the histogram icon when in the yield view, you can choose to Print/Plot versus iteration - and then plot one of the things you're measuring.
    In general using the Low Discrepancy Sequence sampling mode will have better convergence (of sigma) than Random so I'd suggest using that. You can also use one of the Auto Stop methods to run sufficient simulations to ensure that the yield is known to a confidence level (rather than just crossing your fingers).
    So I don't really understand what you are saying about having different results at every hierarchy - but I suspect this is just another case of you reading too much into a specific sample when what matters is the set of samples that makes up the distribution.
    Note that if you are trying to create statistical corners (to allow you to explore changes to the design under a particularly bad sample), then if you're going to change the topology of the circuit, it's advisable to use:
    envSetVal("adexl.monte" "createStatisticalCornerType" 'cyclic "prompt")
    or
    envSetVal("adexl.monte" "createStatisticalCornerType" 'cyclic "promptValues")
    (you can set it to "values" too rather than the default "sequence"). This means that you'll be prompted to create statistical corners using value-based corners rather than sequence-based corners. Sequence-based corners (the default) just sets the corner to run iteration number N in the corner, and this is sensitive to design topology changes. With value-based corners, they record the statistical parameters for each instance and restore that when the corner is re-run, making them less sensitive to design topology changes. There may currently be a performance penalty when using these value-based corners with large circuits (i.e. with large numbers of statistical variables), but that is being worked on.
    • Vote Up +2 Vote Down
  • Irenexox
    Irenexox over 6 years ago in reply to Andrew Beckett
    I think i have the similar problem with ag2888. When i check mismatch contribution after 200-point monte carlo simulation, i find the dummy resistors takes the first place in the list but they should not contribute to mismatch of the output.
    Could you give a hint of this, please?
    Andrew Beckett over 6 years ago in reply to Irenexox
    That doesn't sound like the same issue. The earlier questions were really about the fact that adding in the dummy devices changed the results (which is not surprising). You're talking about mismatch contribution, which is a different level of analysis, and I wouldn't expect a device that is not part of the circuit to be a significant (other than small numerical modelling error) contribution to the variation of an output.
    Rather than continuing this on a 4-year old thread which is unlikely to be similar, this would be best handled via customer support so that we can see your data and set up and try to figure out what's going on.
