  3. Issues with GIOLIB045 and GSCLIB045 PDKs
  • Views 17551
emax
emax over 10 years ago
I requested my University to install 45nm libraries from Cadence and both GIOLIB045 and GSCLIB045 seems to have lot of mismatch issues and looks like incomplete migration from 90 to 45nm PDK.
There are lot of references to GPDK090 and tons of DRC and LVS errors. Am I the only one experiencing these issues?
  • Quek
    Quek over 10 years ago
    Hi emax
    Would you please help to provide the following info?
    a. Version of giolib045 and gsclib045 which you are using
    b. Please provide an example of "Lots of references to gpdk090"
    c. Please provide an example of "tons of DRC and LVS errors"
    d. Are you using Assura or PVS for DRC/LVS?
    Best regards
    Quek
  • emax
    I don't know because I don't have access however, I asked the network administrator and he had them downloaded couple of months before.
    Most of the references of sub-blocks point to gpdk090 both in schematic and layout for the two libraries. For example in giolib045 library IORINGxxx cells have links to gpdk090 library.
    Then again, the pads library have larger contacts not allowed in 45nm DRC rules, metal width violations in BONDPAD52, the active sub-blocks for pads point to 90nm transistors etc.
    Assure DRC/LVS.
    I should admit that our network administrator is LAZY and if asked to download a new PDK and install, either he ignores or do it after months.
    These are indeed fabless PDKs and it does not make sense for restricted access if someone wants to use them for course labs or research.
    BTW such restriction policies  will have DECREASED-USAGE and spins the company to loss!
    I had checked the latest version of the standard cell and IO libraries:
    gsclib045_all_v4.4 and giolib045_v3.2
    In the root of these libraries (i.e. the directory containing the libraries themselves - the ones you'd reference in your cds.lib) there should be a file called "release" which would give the version number.
    I checked using some SKILL code that I have and there are no references to gpdk090 - it's all 45nm technology and the libraries themselves. I also did a couple of quick Assura DRC/LVS of certain cells (not the IO library because I didn't have time) and that ran OK.
    So my guess is that you have an old version (or a corrupted version).
    If you are a company that is under software maintenance, then you can have a Cadence Online Support login yourself - you just need to know the hostid of the license server to register. If you are from academia, then there's info at:  and
