  3. simulation directory for simulation results in ADE
  • Views 20161
MarkGr15
MarkGr15 over 10 years ago
I am trying to figure out how to get the ADE simulation directory to come up with a different default. I am referring to the "project directory" under ADE -> Setup -> Simulator/Directory/Host.
I have tried setting this in my .cdsinit where I bring up cadence:
envSetVal("asimenv.startup" "projectDir" 'string "/sim-output/cadence/mgraumlich")
I have separately tried this in my .cdsenv
asimenv.startup projectDir string "/sim-output/cadence/mgraumlich"
neither of these work.  I am using: version IC6.1.6-64b.500.13.2
thanks
Mark
    Hi Mark,
    The only explanation I can think of is that something else in your environment is setting this after you have. Before starting ADE, check in the CIW:
    envGetVal("asimenv.startup" "projectDir")
    to see what it's set to.
    Kind Regards,
  • MarkGr15
    Andrew:
    returns:
    "simulation"
    any idea where this might be set?
    thanks
    Mark
