  3. need help to scale mosaic or instances
  • Views 16125
imaneet
imaneet over 10 years ago
From the old ic5 version there's a scale function but we're using ic6 now and it's not there anymore.
Can anyone help me with a skill code to resize/scale mosaic or instance.
Also i've searched the forums and there's supposed to be a VLM tool, but i'm not sure where it is.
Thanks.
    The equivalent command is XScale in IC61X.
  • imaneet
    Hi Andrew, how do you use xscale? i looked on the skill finder and i only see "awserxscale". Thanks for the help.
    Andrew, now i found the thread you are referring to about using XScale, it needs to be used in the terminal window, but when i type in XScale on terminal window, it says command not found.
    there's also a "size" function but it doesn't work on instance or mosaic, it says only shapes can be sized.
    I'm guessing that you have some wrapper around virtuoso, because it's in the same directory as the virtuoso executable:
    UNIX> which XScale
    /export/home/apps/IC616_isr/tools/dfII/bin/XScale
    (of course the root to the start of the installation is my own, but the bit beyond the IC616_isr should be uniform).
