  3. Assura LVS Error (Execution Terminated)
  • Replies 7
  • Views 21280
Sattar72
Sattar72 over 10 years ago
Version: Cadence 6.1.5.
Technology & Process: GPDK180nm
Verification Check: Assura DRC, LVS
I am Working on Cadence 6.1.5 version. I have designed Double tail comparator. While i am running Assura LVS. In log file i am getting error in Extract Rule File (divaEXT.rul). In log file Error exist in rule file. That is given by Foundry. So i am providing log file can someone help me.
Thanks in Advance,
LVSDoubletailcomparator.log File:
Assura (tm) Physical Verification Version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10
Release 4.1_USR2_HF2
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:07 (sjfdl081) $
sub-version 4.1_USR2_HF2, integ signature 2011-01-19-0844
run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/assura on Mon May 2 16:10:35 2016
Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/aveng /root/LVSDoubletailComparator/DoubletailComparator.rsf -exec1 -LVS -cdslib /root/cds.lib
@(#)$CDS: aveng_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:08 (sjfdl081) $
run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/aveng on Mon May 2 16:10:35 2016
Summary Report: DoubletailComparator.sum
RSF : /root/LVSDoubletailComparator/DoubletailComparator.rsf
Library Name : AnalogSAS
CDSLIB Path : "/root/cds.lib"
Cell Name : DoubletailComparator
View Name : layout
Rules File : /root/libs.oa22/gpdk180/divaEXT.rul
Options : -exec1 -LVS -cdslib /root/cds.lib
Work Directory: /root/LVSDoubletailComparator
Operating Mode: Legacy Mode is Off
Starting dfIIToVdb...
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.45s.
@(#)$CDS: dfIIToVdb_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:09 (sjfdl081) $
run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/dfIIToVdb on Mon May 2 16:10:35 2016
Loading gpdk180/libInit.il ...
Loading gpdk180/loadCxt.ile ... done!
Loading context 'gpdk180' from library 'gpdk180' ... done!
Loading context 'pdkUtils' from library 'gpdk180' ... done!
Loading gpdk180/.cdsenv ... done!
Loading gpdk180/libInitCustomExit.il ...
* Cadence Design Systems, Inc.                                          *
* Generic 180nm PDK                                                            *
* (gpdk180)        *
* Version 3.2        *
done!
Loaded gpdk180/libInit.il successfully!
*WARNING* Cannot find /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/dfII/etc/tools/spectre directory to load environment variables
Compiling rules...
info: geomErase is not supported in Assura.
1. geomErase("marker" "warning")
2. geomErase("marker" "error")
ERROR Unknown option 'voids' is found in geomHoles().
146. geomHoles(Nwell voids)
Errors exist in the rules file '/root/libs.oa22/gpdk180/divaEXT.rul'.
***** dfIIToVdb terminated abnormally *****
*WARNING* Translation abnormally terminated!
***** aveng fork terminated abnormally *****
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
Thanks & Regards
Sattar
    First of all there's no "foundry" with gpdk180 - it's a Generic 0.18um PDK provided by Cadence intended to illustrate flows, rather than being a real process.
    Secondly, you're using the Diva rules with Assura. That won't work. I don't know why you're doing that, when gpdk180 contains the Assura rules...
    In the gpdk180 installation, there should be a file called "assura_tech.lib". In your working directory, create a file called assura_tech.lib with this content:
    INCLUDE /path/to/gpdk180installation/assura_tech.lib
    and then Assura should be able to pick up the rule data easily enough.
  • Sattar72
    Hi Andrew, yes it is generic. In my working directory i am having assura_tech.lib. I included path also for assura_tech.lib. But I don't know what is the problem. Why Diva rules with Assura won't work because of generic. How can i approach. Please suggest me anyone.
    When the form first appears, it picks up the old Diva rules from within the library. Some Diva rules can be run with Assura - but not all - they sometimes need some modification. Given that this PDK has Assura rules delivered with it, it's better to use those. However, you need to pick them up by specifying the technology choice:
    The choices will come from the assura_tech.lib - which then would set choices for the Rule Set. If I use this cyclic field and pick gpdk180, I then get:
    So then you can see it's pointing at the Assura rules rather than the Diva rules. Once you've run one LVS with this setup, it would remember that in the last state information for this working directory (or you could use Save State at the bottom of the form).
  • Sattar72
    Thank you Andrew. I came to know difference between Diva and Assura Rule File. Actually by using Assura rules I am getting warning and Errors. I am having one doubt if i am not having spectre tool for Schematic, then i be able to do LVS. Can i post the log file. Thanks & Regards Sattar
    I'm confused. Spectre is not a schematic tool - it's a simulator. LVS is nothing to do with what simulator you use.
    You can post the log file here, but I can't guarantee to be able to debug your problem as it may be dependent upon seeing the design (and even then that's not something I can guarantee to do in my spare time).
  • Sattar72
    Sorry, yes spectre is simulator for schematc. Actually what i am supposed to ask means if schematic is designed but i am not verified with spectre simulator or may be spectre file is missing. If I run LVS will it get results clean if i have done proper connections. I am posting log file please go through it. LVSDoubletailComparator.log
    run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/assura on Fri May 6 18:16:34 2016
    run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/aveng on Fri May 6 18:16:34 2016
    Loading tech rule set file : /root/pv/assura/techRuleSets
    View Name : layout
    Rules File : /root/pv/assura/extract.rul
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.44s.
    run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/dfIIToVdb on Fri May 6 18:16:35 2016
    * (gpdk180) *
    * Version 3.2 *
    done!
    Compiling rules...
    WARNING LVS Run detected.
    Non-legacy mode has been disabled for this LVS run
    Checking out license for Assura_LVS 4.10
    *WARNING* Failed to obtain license for Assura_LVS 4.10
    No Assura license available.
    Checking out license for Phys_Ver_Sys_LVS_XL 10.10
    Reading the design data...
    Finished dfIIToVdb.
    Building the VDB part 2 in background mode.
    Building tables for LVS Preprocessing in background mode.
    Starting /opt/cadence/ASSURA41OAISR_lnx86/tools/assura/bin/vdbToCells /root/LVSDoubletailComparator DoubletailComparator
    Finished /opt/cadence/ASSURA41OAISR_lnx86/tools/assura/bin/vdbToCells
    Starting Nvn PreExtraction...
    Starting /opt/cadence/ASSURA41OAISR_lnx86/tools/assura/bin/nvn /root/LVSDoubletailComparator/DoubletailComparator.rsf -preExtract -exec1 -cdslib /root/cds.lib
    @(#)$CDS: nvn_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:10 (sjfdl081) $
    run on localhost.localdomain at Fri May 6 18:16:38 2016
    GENERIC PDK Assura Compare Rules file version 2.3
    PDK Technology Center, Melbourne, FL
    Aug 2005
    Use with GENERIC PDK Process version 2.3
    Reference Documents:
    Library Specification No. GPDK, Version 2.3
    NOTICE:
    Cadence Design Systems shall not be liable for the accuracy
    of this LVS rule file or its ability to capture errors.
    The user is responsible for thoroughly testing and
    implementing its features.
    Reading schematic network
    running dfIIToVldb -cdslib /root/cds.lib /root/LVSDoubletailComparator/DoubletailComparator.vlr /root/LVSDoubletailComparator/DoubletailComparator.rsf
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.47s.
    @(#)$CDS: dfIIToVldb_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:09 (sjfdl081) $
    run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/dfIIToVldb on Fri May 6 18:16:39 2016
    Aug 2005
    NOTICE:
    Top Cell Library: "AnalogSAS"
    Top Cell Name: "DoubletailComparator"
    Top Cell View: "schematic"
    Output Data Base Name: "/root/LVSDoubletailComparator/DoubletailComparator.sdb"
    Simulator Name: "auLvs"
    ERROR (LMF-02018): License call failed for feature Assura_LVS, version 4.100 and quantity 1. The license server search path is defined as 5280@bkbietabtrc:5280@bkbietabtrc. The FLEXnet error message is as follows,
    FLEXnet ERROR(-18, 0, 0): License server system does not support this feature.
    Run 'lic_error LMF-02018' for more information.
    Failed to obtain license for "Assura_LVS".
    View List: "auLvs schematic symbol"
    Stop List: "auLvs"
    * (gpdk180) *
    * Version 3.2 *
    done!
    Net Listing Mode is Digital
    Global net vdd! found
    Global net vss! found
    writing /root/LVSDoubletailComparator/DoubletailComparator.sdb
    inputting /root/LVSDoubletailComparator/DoubletailComparator.sdb
    Reading layout network
    inputting network ./LVSDoubletailComparator/DoubletailComparator.ldb
    Preprocessing schematic network phase 1
    Preprocessing layout network phase 1
    Preprocessing schematic network phase 2
    Preprocessing layout network phase 2
    cpu=0.00m wall=0.03m mem=35.75mb
    Finished /opt/cadence/ASSURA41OAISR_lnx86/tools/assura/bin/nvn
    Executing: bulk = cellBoundary(root)
    Building the VDB part 3 in background mode.
    Finished building the VDB. VDB build times for main process:
    cpu: 0.11 elap: 6 pf: 0 in: 0 out: 10152 virt: 98M phys: 562M
    Running the Task Processor, 1 cells, 1610 steps...
    Top Cell is 'DoubletailComparator layout AnalogSAS'
    Executing: CapMetal = geomOr(CapMetal CapMetal_pin)
    Executing: INDdummy = geomOr(INDdummy INDdummy_pin)
    Executing: JVAR1dummy = geomOr(JVAR1dummy JVAR1dummy_pin)
    Executing: Metal1 = geomOr(Metal1_d Metal1_f)
    Executing: Metal2 = geomOr(Metal2_d Metal2_f)
    Executing: Metal3 = geomOr(Metal3_d Metal3_f)
    Executing: Metal4 = geomOr(Metal4_d Metal4_f)
    Executing: Metal5 = geomOr(Metal5_d Metal5_f)
    Executing: Metal6 = geomOr(Metal6_d Metal6_f)
    Executing: Metal1 = geomOr(Metal1 Metal1_pin)
    Executing: Metal2 = geomOr(Metal2 Metal2_pin)
    Executing: Metal3 = geomOr(Metal3 Metal3_pin)
    Executing: Metal4 = geomOr(Metal4 Metal4_pin)
    Executing: Metal5 = geomOr(Metal5 Metal5_pin)
    Executing: Metal6 = geomOr(Metal6 Metal6_pin)
    Executing: Nburied = geomOr(Nburied Nburied_pin)
    Executing: Nimp = geomOr(Nimp Nimp_pin)
    Executing: Nwell = geomOr(Nwell Nwell_pin)
    Executing: Pimp = geomOr(Pimp Pimp_pin)
    Executing: Poly = geomOr(Poly Poly_pin)
    Executing: Pwell = geomOr(Pwell Pwell_pin)
    Executing: INDterm1 = geomAnd(IND2dummy INDdummy)
    Executing: INDterm2 = geomAnd(IND3dummy INDdummy)
    Executing: JVARNF = geomAnd(JVAR1dummy Nwell)
    Executing: JVARW40 = geomAnd(JVAR2dummy Nwell)
    Executing: M1res = geomAnd(M1dummy Metal1)
    Executing: M1term = geomAndNot(Metal1 M1dummy)
    Executing: M2res = geomAnd(M2dummy Metal2)
    Executing: M2term = geomAndNot(Metal2 M2dummy)
    Executing: M3res = geomAnd(M3dummy Metal3)
    Executing: M3term = geomAndNot(Metal3 M3dummy)
    Executing: M4res = geomAnd(M4dummy Metal4)
    Executing: M4term = geomAndNot(Metal4 M4dummy)
    Executing: M5res = geomAnd(M5dummy Metal5)
    Executing: M5term = geomAndNot(Metal5 M5dummy)
    Executing: M6res = geomAnd(M6dummy Metal6)
    Executing: M6term = geomAndNot(Metal6 M6dummy)
    Executing: NPLUS = geomAnd(Nimp Oxide)
    Executing: NSD = geomAndNot(NPLUS Poly)
    Executing: NSDcont = geomAnd(Cont NPLUS)
    Executing: NSDterm = geomAndNot(NSD Resdum)
    Executing: NWELLRES = geomAnd(Nwell ResWdum)
    Executing: NWELLterm = geomAndNot(Nwell ResWdum)
    Executing: NBVIA = geomAnd(NWELLterm Nburied)
    Executing: NWVIA = geomAnd(NSDterm NWELLterm)
    Executing: POLYcont = geomAnd(Cont Poly)
    Executing: POLYterm = geomAndNot(Poly Resdum)
    Executing: PPLUS = geomAnd(Oxide Pimp)
    Executing: PSD = geomAndNot(PPLUS Poly)
    Executing: PSDcont = geomAnd(Cont PPLUS)
    Executing: PSDterm = geomAndNot(PSD Resdum)
    Executing: Via2Cap = geomAnd(CapMetal Via2)
    Executing: L41497 = geomAnd(INDdummy Metal2)
    Executing: INDterm1Cont = geomAnd(IND2dummy L41497)
    Executing: INDterm2Cont = geomAnd(IND3dummy L41497)
    Executing: L29658 = geomAnd(NSD Resdum)
    Executing: ISONSDRES = geomAnd(L29658 Nburied)
    Executing: L74850 = geomOr(JVAR1dummy JVAR2dummy)
    Executing: JVARanode = geomAndNot(L74850 NSDterm)
    Executing: L62925 = geomAnd(CapMetal Metal2)
    Executing: MIMCAP = geomAnd(Capdum L62925)
    Executing: L83619 = geomAndNot(NSDterm Nwell)
    Executing: NDIODE = geomAnd(DIOdummy L83619)
    Executing: NSDRES = geomAndNot(L29658 Nburied)
    Executing: L33580 = geomAnd(DIOdummy PSDterm)
    Executing: PDIODE = geomAnd(L33580 Nwell)
    Executing: L99065 = geomAnd(Poly Resdum)
    Executing: POLYHRES = geomAnd(L99065 SiProt)
    Executing: POLYRES = geomAndNot(L99065 SiProt)
    Executing: L77701 = geomAnd(PPLUS Resdum)
    Executing: PSDRES = geomAnd(L77701 Nwell)
    Executing: L33566 = geomAnd(PSDterm Pwell)
    Executing: PWVIA = geomAndNot(L33566 Nwell)
    Executing: L32940 = geomOr(IND2dummy Metal3)
    Executing: L19763 = geomOr(IND3dummy L32940)
    Executing: INDUCTOR = geomAnd(INDdummy L19763)
    Executing: L40384 = geomAnd(L74850 PSDterm)
    Executing: JVARterm = geomAnd(JVAR3dummy L40384)
    Executing: L77885 = geomAnd(NPNdummy Pwell)
    Executing: L63415 = geomAnd(L77885 Nburied)
    Executing: NPN = geomAnd(L63415 NSDterm)
    Executing: L8539 = geomAnd(Nwell POLYterm)
    Executing: L93040 = geomAnd(L8539 PPLUS)
    Executing: PMOSCAP = geomAnd(Capdum L93040)
    Executing: L98704 = geomAnd(Metal2 Via2)
    Executing: L47735 = geomOr(CapMetal INDdummy)
    Executing: Via2NoCapInd = geomAndNot(L98704 L47735)
    Executing: L26152 = geomAndNot(POLYterm Nwell)
    Executing: L2255 = geomAnd(L26152 NPLUS)
    Executing: L68673 = geomAnd(Capdum L2255)
    Executing: ISONMOSCAP = geomAnd(L68673 Nburied)
    Executing: NMOSCAP = geomAndNot(L68673 Nburied)
    Executing: L56230 = geomAndNot(L93040 ThickOxide)
    Executing: PMOS = geomAndNot(L56230 Capdum)
    Executing: L99549 = geomAnd(Nwell PNPdummy)
    Executing: L64651 = geomAnd(L99549 Pwell)
    Executing: L49368 = geomAnd(L64651 Nburied)
    Executing: PNP = geomAnd(L49368 PSDterm)
    Executing: L43094 = geomOr(Nburied Nwell)
    Executing: L15547 = geomOr(L43094 Pwell)
    Executing: L71054 = geomAndNot(bulk L15547)
    Executing: PSUB = geomOr(BJTdum L71054)
    Executing: L6892 = geomAnd(PSDterm PSUB)
    Executing: L56122 = geomAndNot(L6892 Nburied)
    Executing: SUBVIA = geomAndNot(L56122 Nwell)
    Executing: L53692 = geomAndNot(L2255 ThickOxide)
    Executing: L70081 = geomAndNot(L53692 Capdum)
    Executing: ISONMOS = geomAnd(L70081 Nburied)
    Executing: geomHoles(Nwell)
    Executing: L90545 = geomAndNot(L85630 Nwell)
    Executing: L50707 = geomEnclose(Nburied L90545)
    Executing: L9133 = geomAnd(L50707 L90545)
    Executing: ISOPWELL = geomAndNot(L9133 Pwell)
    Executing: PWNBVIA = geomAnd(ISOPWELL PSDterm)
    Executing: NMOS = geomAndNot(L70081 Nburied)
    Executing: L68469 = geomAnd(L93040 ThickOxide)
    Executing: L24157 = geomAndNot(L68469 Capdum)
    Executing: PMOSHV = geomAndNot(L24157 RFdummy)
    Executing: PMOSRF = geomAnd(L24157 RFdummy)
    Executing: L28865 = geomAnd(L2255 ThickOxide)
    Executing: L34783 = geomAndNot(L28865 Capdum)
    Executing: L93445 = geomAnd(L34783 Nburied)
    Executing: ISONMOSHV = geomAndNot(L93445 RFdummy)
    Executing: ISONMOSRF = geomAnd(L93445 RFdummy)
    Executing: L21312 = geomAndNot(L34783 Nburied)
    Executing: NMOSHV = geomAndNot(L21312 RFdummy)
    Executing: NMOSRF = geomAnd(L21312 RFdummy)
    Executing: L22688 = geomAnd(Nwell PSDterm)
    Executing: geomHoles(PSDterm)
    Executing: L40992 = geomAndNot(L98291 PSDterm)
    Executing: geomHoles(NSDterm)
    Executing: L66370 = geomAndNot(L48335 NSDterm)
    Executing: L20204 = geomButtOrOver(L40992 L66370)
    Executing: L80937 = geomAvoiding(L20204 Poly)
    Executing: L48389 = geomButtOrOver(L22688 L80937)
    Executing: VPNP = geomAnd(BJTdum L48389)
    Executing: geomConnect((via Via5 M6term M5term) (via Via4 M5term M4term) (via Via3 M4ter...
    See the label report in "DoubletailComparator.erc" file for details.
    Executing: geomStamp(NWVIA NSDterm error)
    Executing: geomStamp(NWELLterm NWVIA error)
    Executing: geomStamp(JVARterm PSDterm error)
    Executing: geomStamp(JVARanode JVARterm error)
    Executing: geomStamp(PWVIA PSDterm error)
    Executing: geomStamp(Pwell PWVIA error)
    Executing: geomStamp(PWNBVIA PSDterm error)
    Executing: geomStamp(ISOPWELL PWNBVIA error)
    Executing: geomStamp(SUBVIA PSDterm error)
    Executing: geomStamp(PSUB SUBVIA error)
    Executing: geomStamp(NBVIA NWELLterm error)
    Executing: geomStamp(Nburied NBVIA error)
    Executing: (saveInterconnect (M6term "Metal6"))
    Executing: (saveInterconnect (M5term "Metal5"))
    Executing: (saveInterconnect (M4term "Metal4"))
    Executing: (saveInterconnect (M3term "Metal3"))
    Executing: (saveInterconnect (M2term "Metal2"))
    Executing: (saveInterconnect (M1term "Metal1"))
    Executing: (saveInterconnect (NSDterm "Nimp"))
    Executing: (saveInterconnect (PSDterm "Pimp"))
    Executing: (saveInterconnect (NWELLterm "Nwell"))
    Executing: (saveInterconnect (CapMetal "CapMetal"))
    Executing: (saveInterconnect (INDterm1 "INDdummy"))
    Executing: (saveInterconnect (INDterm2 "INDdummy"))
    Executing: (saveInterconnect (POLYterm "Poly"))
    Executing: (saveInterconnect (JVARanode "JVAR1dummy"))
    Executing: (saveInterconnect (Pwell "Pwell"))
    Executing: (saveInterconnect (ISOPWELL "Nburied"))
    Executing: (saveInterconnect (Nburied "Nburied"))
    Executing: extractRES("polyres" POLYRES (POLYterm "PLUS" "MINUS") (cellView "polyres ivp...
    Executing: attachParameter(w "w" POLYRES)
    Executing: attachParameter(l "l" POLYRES)
    Executing: attachParameter(sl "sl" POLYRES)
    Executing: attachParameter(effL "effL" POLYRES)
    Executing: attachParameter(r "r" POLYRES)
    Executing: extractRES("polyhres" POLYHRES (POLYterm "PLUS" "MINUS") (cellView "polyhres ...
    Executing: attachParameter(w "w" POLYHRES)
    Executing: attachParameter(l "l" POLYHRES)
    Executing: attachParameter(sl "sl" POLYHRES)
    Executing: attachParameter(effL "effL" POLYHRES)
    Executing: attachParameter(r "r" POLYHRES)
    Executing: extractRES("nplusres" NSDRES (NSDterm "PLUS" "MINUS") (PSUB "B") (cellView "n...
    Executing: attachParameter(w "w" NSDRES)
    Executing: attachParameter(l "l" NSDRES)
    Executing: attachParameter(sl "sl" NSDRES)
    Executing: attachParameter(effL "effL" NSDRES)
    Executing: attachParameter(r "r" NSDRES)
    Executing: extractRES("nplusres" ISONSDRES (NSDterm "PLUS" "MINUS") (ISOPWELL "B") (cell...
    Executing: attachParameter(w "w" ISONSDRES)
    Executing: attachParameter(l "l" ISONSDRES)
    Executing: attachParameter(sl "sl" ISONSDRES)
    Executing: attachParameter(effL "effL" ISONSDRES)
    Executing: attachParameter(r "r" ISONSDRES)
    Executing: extractRES("pplusres" PSDRES (PSDterm "PLUS" "MINUS") (NWELLterm "B") (cellVi...
    Executing: attachParameter(w "w" PSDRES)
    Executing: attachParameter(l "l" PSDRES)
    Executing: attachParameter(sl "sl" PSDRES)
    Executing: attachParameter(effL "effL" PSDRES)
    Executing: attachParameter(r "r" PSDRES)
    Executing: extractRES("nwellres" NWELLRES (NWELLterm "PLUS" "MINUS") (cellView "nwellres...
    Executing: attachParameter(w "w" NWELLRES)
    Executing: attachParameter(l "l" NWELLRES)
    Executing: attachParameter(sl "sl" NWELLRES)
    Executing: attachParameter(effL "effL" NWELLRES)
    Executing: attachParameter(r "r" NWELLRES)
    Executing: extractRES("m1res" M1res (M1term "PLUS" "MINUS") (cellView "m1res ivpcell gpd...
    Executing: attachParameter(w "w" M1res)
    Executing: attachParameter(l "l" M1res)
    Executing: attachParameter(sl "sl" M1res)
    Executing: attachParameter(effL "effL" M1res)
    Executing: attachParameter(r "r" M1res)
    Executing: extractRES("m2res" M2res (M2term "PLUS" "MINUS") (cellView "m2res ivpcell gpd...
    Executing: attachParameter(w "w" M2res)
    Executing: attachParameter(l "l" M2res)
    Executing: attachParameter(sl "sl" M2res)
    Executing: attachParameter(effL "effL" M2res)
    Executing: attachParameter(r "r" M2res)
    Executing: extractRES("m3res" M3res (M3term "PLUS" "MINUS") (cellView "m3res ivpcell gpd...
    Executing: attachParameter(w "w" M3res)
    Executing: attachParameter(l "l" M3res)
    Executing: attachParameter(sl "sl" M3res)
    Executing: attachParameter(effL "effL" M3res)
    Executing: attachParameter(r "r" M3res)
    Executing: extractRES("m4res" M4res (M4term "PLUS" "MINUS") (cellView "m4res ivpcell gpd...
    Executing: attachParameter(w "w" M4res)
    Executing: attachParameter(l "l" M4res)
    Executing: attachParameter(sl "sl" M4res)
    Executing: attachParameter(effL "effL" M4res)
    Executing: attachParameter(r "r" M4res)
    Executing: extractRES("m5res" M5res (M5term "PLUS" "MINUS") (cellView "m5res ivpcell gpd...
    Executing: attachParameter(w "w" M5res)
    Executing: attachParameter(l "l" M5res)
    Executing: attachParameter(sl "sl" M5res)
    Executing: attachParameter(effL "effL" M5res)
    Executing: attachParameter(r "r" M5res)
    Executing: extractRES("m6res" M6res (M6term "PLUS" "MINUS") (cellView "m6res ivpcell gpd...
    Executing: attachParameter(w "w" M6res)
    Executing: attachParameter(l "l" M6res)
    Executing: attachParameter(sl "sl" M6res)
    Executing: attachParameter(effL "effL" M6res)
    Executing: attachParameter(r "r" M6res)
    Executing: extractCAP("mimcap" MIMCAP (CapMetal "PLUS") (M2term "MINUS") (cellView "mimc...
    Executing: attachParameter(w "w" MIMCAP)
    Executing: attachParameter(l "l" MIMCAP)
    Executing: attachParameter(c "c" MIMCAP)
    Executing: attachParameter(area "area" MIMCAP)
    Executing: attachParameter(perim "perim" MIMCAP)
    Executing: extractMOS("pmoscap" PMOSCAP (POLYterm "G") (PSDterm "S" "D") (NWELLterm "B")...
    Executing: attachParameter(w "w" PMOSCAP)
    Executing: attachParameter(fw "fw" PMOSCAP)
    Executing: attachParameter(simW "simW" PMOSCAP)
    Executing: attachParameter(l "l" PMOSCAP)
    Executing: extractMOS("nmoscap" NMOSCAP (POLYterm "G") (NSDterm "S" "D") (PSUB "B") (cel...
    Executing: attachParameter(w "w" NMOSCAP)
    Executing: attachParameter(fw "fw" NMOSCAP)
    Executing: attachParameter(simW "simW" NMOSCAP)
    Executing: attachParameter(l "l" NMOSCAP)
    Executing: extractMOS("nmoscap" ISONMOSCAP (POLYterm "G") (NSDterm "S" "D") (ISOPWELL "B...
    Executing: attachParameter(w "w" ISONMOSCAP)
    Executing: attachParameter(fw "fw" ISONMOSCAP)
    Executing: attachParameter(simW "simW" ISONMOSCAP)
    Executing: attachParameter(l "l" ISONMOSCAP)
    Executing: extractDevice("ind" INDUCTOR (INDterm1 "PLUS") (INDterm2 "MINUS") (cellView "...
    Executing: extractBJT("vpnp" VPNP (PSUB "C") (NWELLterm "B") (PSDterm "E") (cellView "vp...
    Executing: attachParameter(area "area" VPNP)
    Executing: extractBJT("pnp" PNP (Pwell "C") (NWELLterm "B") (PSDterm "E") (cellView "pnp...
    Executing: attachParameter(area "area" PNP)
    Executing: extractBJT("npn" NPN (Nburied "C") (Pwell "B") (NSDterm "E") (cellView "npn i...
    Executing: attachParameter(area "area" NPN)
    Executing: extractMOS("nmos" NMOS (POLYterm "G") (NSDterm "S" "D") (PSUB "B") (cellView ...
    9 'nmos' created in cell 'DoubletailComparator layout AnalogSAS'.
    Executing: attachParameter(w "w" NMOS)
    Executing: attachParameter(fw "fw" NMOS)
    Executing: attachParameter(simW "simW" NMOS)
    Executing: attachParameter(l "l" NMOS)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") NMOS shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") NMOS shared)
    Executing: extractMOS("nmos" ISONMOS (POLYterm "G") (NSDterm "S" "D") (ISOPWELL "B") (ce...
    Executing: attachParameter(w "w" ISONMOS)
    Executing: attachParameter(fw "fw" ISONMOS)
    Executing: attachParameter(simW "simW" ISONMOS)
    Executing: attachParameter(l "l" ISONMOS)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") ISONMOS shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") ISONMOS shared)
    Executing: extractMOS("nmoshv" NMOSHV (POLYterm "G") (NSDterm "S" "D") (PSUB "B") (cellV...
    Executing: attachParameter(w "w" NMOSHV)
    Executing: attachParameter(fw "fw" NMOSHV)
    Executing: attachParameter(simW "simW" NMOSHV)
    Executing: attachParameter(l "l" NMOSHV)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") NMOSHV shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") NMOSHV shared)
    Executing: extractMOS("nmoshv" ISONMOSHV (POLYterm "G") (NSDterm "S" "D") (ISOPWELL "B")...
    Executing: attachParameter(w "w" ISONMOSHV)
    Executing: attachParameter(fw "fw" ISONMOSHV)
    Executing: attachParameter(simW "simW" ISONMOSHV)
    Executing: attachParameter(l "l" ISONMOSHV)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") ISONMOSHV shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") ISONMOSHV shared)
    Executing: extractMOS("nmosrf" NMOSRF (POLYterm "G") (NSDterm "S" "D") (PSUB "B") (cellV...
    Executing: attachParameter(w "w" NMOSRF)
    Executing: attachParameter(fw "fw" NMOSRF)
    Executing: attachParameter(simW "simW" NMOSRF)
    Executing: attachParameter(l "l" NMOSRF)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") NMOSRF shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") NMOSRF shared)
    Executing: extractMOS("nmosrf" ISONMOSRF (POLYterm "G") (NSDterm "S" "D") (ISOPWELL "B")...
    Executing: attachParameter(w "w" ISONMOSRF)
    Executing: attachParameter(fw "fw" ISONMOSRF)
    Executing: attachParameter(simW "simW" ISONMOSRF)
    Executing: attachParameter(l "l" ISONMOSRF)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") ISONMOSRF shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") ISONMOSRF shared)
    Executing: extractMOS("pmos" PMOS (POLYterm "G") (PSDterm "S" "D") (NWELLterm "B") (cell...
    7 'pmos' created in cell 'DoubletailComparator layout AnalogSAS'.
    Executing: attachParameter(w "w" PMOS)
    Executing: attachParameter(fw "fw" PMOS)
    Executing: attachParameter(simW "simW" PMOS)
    Executing: attachParameter(l "l" PMOS)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") PMOS shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") PMOS shared)
    Executing: extractMOS("pmoshv" PMOSHV (POLYterm "G") (PSDterm "S" "D") (NWELLterm "B") (...
    Executing: attachParameter(w "w" PMOSHV)
    Executing: attachParameter(fw "fw" PMOSHV)
    Executing: attachParameter(simW "simW" PMOSHV)
    Executing: attachParameter(l "l" PMOSHV)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") PMOSHV shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") PMOSHV shared)
    Executing: extractMOS("pmosrf" PMOSRF (POLYterm "G") (PSDterm "S" "D") (NWELLterm "B") (...
    Executing: attachParameter(w "w" PMOSRF)
    Executing: attachParameter(fw "fw" PMOSRF)
    Executing: attachParameter(simW "simW" PMOSRF)
    Executing: attachParameter(l "l" PMOSRF)
    Executing: attachParameter(sdarea ("as" "S") ("ad" "D") PMOSRF shared)
    Executing: attachParameter(sdperimeter ("ps" "S") ("pd" "D") PMOSRF shared)
    Executing: extractDIODE("ndio" NDIODE (PSUB "PLUS") (NSDterm "MINUS") (cellView "ndio iv...
    Executing: attachParameter(area "area" NDIODE)
    Executing: extractDIODE("pdio" PDIODE (PSDterm "PLUS") (NWELLterm "MINUS") (cellView "pd...
    Executing: attachParameter(area "area" PDIODE)
    Executing: extractDIODE("xjvar_w40" JVARNF (JVARanode "ANODE") (NWELLterm "CATHODE") (PS...
    Executing: attachParameter(nf "nf" JVARNF)
    Executing: extractDIODE("xjvar_nf36" JVARW40 (JVARanode "ANODE") (NWELLterm "CATHODE") (...
    Executing: attachParameter(w "w" JVARW40)
    Finished running rules. Task processor time in main process:
    cpu: 0.19 elap: 0 pf: 0 in: 0 out: 376 virt: 138M phys: 679M
    No output post-processing: This is not a DRC run
    Finished building the persistent database.
    cpu: 0.01 elap: 1 pf: 0 in: 0 out: 6448 virt: 142M phys: 694M
    ***** aveng terminated normally *****
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/aveng
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avrpt /root/LVSDoubletailComparator/DoubletailComparator.rsf
    @(#)$CDS: avrpt_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:08 (sjfdl081) $
    run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/avrpt on Fri May 6 18:16:41 2016
    Creating Error Database 'DoubletailComparator'...
    Reading VDB ...
    Rule Message FlatCount RealCount
    ( 1) dataAuditErrors 0 0
    ( 2) NWVIA_StampErrorFloat 0 0
    ( 3) NWVIA_StampErrorMult 0 0
    ( 4) NWVIA_StampErrorConnect 0 0
    ( 5) NWELLterm_StampErrorFloat 1 1
    ( 6) NWELLterm_StampErrorMult 0 0
    ( 7) NWELLterm_StampErrorConnect 0 0
    ( 8) JVARterm_StampErrorFloat 0 0
    ( 9) JVARterm_StampErrorMult 0 0
    ( 10) JVARterm_StampErrorConnect 0 0
    ( 11) JVARanode_StampErrorFloat 0 0
    ( 12) JVARanode_StampErrorMult 0 0
    ( 13) JVARanode_StampErrorConnect 0 0
    ( 14) PWVIA_StampErrorFloat 0 0
    ( 15) PWVIA_StampErrorMult 0 0
    ( 16) PWVIA_StampErrorConnect 0 0
    ( 17) Pwell_StampErrorFloat 0 0
    ( 18) Pwell_StampErrorMult 0 0
    ( 19) Pwell_StampErrorConnect 0 0
    ( 20) PWNBVIA_StampErrorFloat 0 0
    ( 21) PWNBVIA_StampErrorMult 0 0
    ( 22) PWNBVIA_StampErrorConnect 0 0
    ( 23) ISOPWELL_StampErrorFloat 0 0
    ( 24) ISOPWELL_StampErrorMult 0 0
    ( 25) ISOPWELL_StampErrorConnect 0 0
    ( 26) SUBVIA_StampErrorFloat 0 0
    ( 27) SUBVIA_StampErrorMult 0 0
    ( 28) SUBVIA_StampErrorConnect 0 0
    ( 29) PSUB_StampErrorFloat 0 0
    ( 30) PSUB_StampErrorMult 1 1
    ( 31) PSUB_StampErrorConnect 1 1
    ( 32) NBVIA_StampErrorFloat 0 0
    ( 33) NBVIA_StampErrorMult 0 0
    ( 34) NBVIA_StampErrorConnect 0 0
    ( 35) Nburied_StampErrorFloat 0 0
    ( 36) Nburied_StampErrorMult 0 0
    ( 37) Nburied_StampErrorConnect 0 0
    ( 38) malformed device POLYRES 0 0
    ( 39) malformed device POLYHRES 0 0
    ( 40) malformed device NSDRES 0 0
    ( 41) malformed device ISONSDRES 0 0
    ( 42) malformed device PSDRES 0 0
    ( 43) malformed device NWELLRES 0 0
    ( 44) malformed device M1res 0 0
    ( 45) malformed device M2res 0 0
    ( 46) malformed device M3res 0 0
    ( 47) malformed device M4res 0 0
    ( 48) malformed device M5res 0 0
    ( 49) malformed device M6res 0 0
    ( 50) malformed device MIMCAP 0 0
    ( 51) malformed device PMOSCAP 0 0
    ( 52) malformed device NMOSCAP 0 0
    ( 53) malformed device ISONMOSCAP 0 0
    ( 54) malformed device INDUCTOR 0 0
    ( 55) malformed device VPNP 0 0
    ( 56) malformed device PNP 0 0
    ( 57) malformed device NPN 0 0
    ( 58) malformed device NMOS 0 0
    ( 59) malformed device ISONMOS 0 0
    ( 60) malformed device NMOSHV 0 0
    ( 61) malformed device ISONMOSHV 0 0
    ( 62) malformed device NMOSRF 0 0
    ( 63) malformed device ISONMOSRF 0 0
    ( 64) malformed device PMOS 0 0
    ( 65) malformed device PMOSHV 0 0
    ( 66) malformed device PMOSRF 0 0
    ( 67) malformed device NDIODE 0 0
    ( 68) malformed device PDIODE 0 0
    ( 69) malformed device JVARNF 0 0
    ( 70) malformed device JVARW40 0 0
    ( 71) unstable device for JVARW40_DIODE_33 0 0
    ( 73) unstable device for JVARNF_DIODE_32 0 0
    ( 75) unstable device for PDIODE_DIODE_31 0 0
    ( 77) unstable device for NDIODE_DIODE_30 0 0
    ( 79) unstable device for PMOSRF_MOS_29 0 0
    ( 81) unstable device for PMOSHV_MOS_28 0 0
    ( 83) unstable device for PMOS_MOS_27 0 0
    ( 85) unstable device for ISONMOSRF_MOS_26 0 0
    ( 87) unstable device for NMOSRF_MOS_25 0 0
    ( 89) unstable device for ISONMOSHV_MOS_24 0 0
    ( 91) unstable device for NMOSHV_MOS_23 0 0
    ( 93) unstable device for ISONMOS_MOS_22 0 0
    ( 95) unstable device for NMOS_MOS_21 0 0
    ( 97) unstable device for NPN_BJT_20 0 0
    ( 99) unstable device for PNP_BJT_19 0 0
    ( 101) unstable device for VPNP_BJT_18 0 0
    ( 103) unstable device for INDUCTOR_Device_17 0 0
    ( 105) unstable device for ISONMOSCAP_MOS_16 0 0
    ( 107) unstable device for NMOSCAP_MOS_15 0 0
    ( 109) unstable device for PMOSCAP_MOS_14 0 0
    ( 111) unstable device for MIMCAP_CAP_13 0 0
    ( 113) unstable device for M6res_RES_12 0 0
    ( 115) unstable device for M5res_RES_11 0 0
    ( 117) unstable device for M4res_RES_10 0 0
    ( 119) unstable device for M3res_RES_9 0 0
    ( 121) unstable device for M2res_RES_8 0 0
    ( 123) unstable device for M1res_RES_7 0 0
    ( 125) unstable device for NWELLRES_RES_6 0 0
    ( 127) unstable device for PSDRES_RES_5 0 0
    ( 129) unstable device for ISONSDRES_RES_4 0 0
    ( 131) unstable device for NSDRES_RES_3 0 0
    ( 133) unstable device for POLYHRES_RES_2 0 0
    ( 135) unstable device for POLYRES_RES_1 0 0
    Total errors: 3 3
    Finished creating Error Database ...
    Writing Report into /root/LVSDoubletailComparator/DoubletailComparator.err ...
    Rule 5 done.
    Rule 30 done.
    Rule 31 done.
    avrpt cpu sec: 0.06 elapsed: 0 virtual: 93M
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avrpt
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avcallproc /root/LVSDoubletailComparator/DoubletailComparator.rsf -exec1 -LVS -cdslib /root/cds.lib
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avcallproc
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avnx /root/LVSDoubletailComparator/DoubletailComparator.rsf -exec1 -LVS -cdslib /root/cds.lib
    @(#)$CDS: avnx_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 01/19/2011 09:08 (sjfdl081) $
    run on localhost.localdomain from /opt/cadence/ASSURA41OAISR_lnx86/tools.lnx86/assura/bin/64bit/avnx on Fri May 6 18:16:43 2016
    avnx started...
    cpu: 0.08 elap: 0 pf: 0 in: 0 out: 16 virt: 373M phys: 660M
    Run time = 1.00 seconds
    CPU time = 0.10 seconds
    End of Summary Report
    cpu: 0.01 elap: 0 pf: 0 in: 0 out: 12944 virt: 302M phys: 660M
    ***** avnx terminated normally *****
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avnx
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/nvn /root/LVSDoubletailComparator/DoubletailComparator.rsf -postExtract -exec1 -cdslib /root/cds.lib
    run on localhost.localdomain at Fri May 6 18:16:44 2016
    Aug 2005
    NOTICE:
    Top cell DoubletailComparator schematic AnalogSAS vs DoubletailComparator layout AnalogSAS
    Compare errors, please see /root/LVSDoubletailComparator/DoubletailComparator.csm and /root/LVSDoubletailComparator/DoubletailComparator.cls files.
    cpu=0.00m wall=0.00m mem=35.91mb
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/nvn
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/vldbToRpa DoubletailComparator.snn DoubletailComparator.tre DoubletailComparator.cel
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/vldbToRpa
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/vldbToRpa DoubletailComparator.lnn DoubletailComparator.tre2 DoubletailComparator.cel2
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/ercChk /root/LVSDoubletailComparator/DoubletailComparator.rsf
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.43s.
    * (gpdk180) *
    * Version 3.2 *
    done!
    Finished /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/ercChk
    Starting /opt/cadence/ASSURA41OAISR_lnx86//tools/assura/bin/avcallproc /root/LVSDoubletailComparator/DoubletailComparator.rsf -trp -exec1
    Assura LVS terminated normally.
    Run ended: Fri May 6 18:16:46 2016
    ***** Assura terminated normally *****
    I have no idea what you're asking here. If you're asking whether it's possible to get LVS clean results without having simulated the design, then the answer is of course yes - LVS is simply matching the connectivity between the schematic and an extraction of the layout. It knows nothing about whether you've simulated it or not.
    The log file doesn't tell me anything very useful - it just says that it managed to go through all the steps to run LVS. The LVS match report will be elsewhere. I can't write in this post a tutorial on how to run and debug Assura LVS - there should be enough on that in the documentation. Or you should speak to your supervisor - it sounds to me as if you don't really know what you're trying to do here...
