  3. Pin snapping in VirtuosoXL
  • Views 16028
climbnc
climbnc over 10 years ago
Is there any built in function in VirtuosoXL that will snap pins at the current level of hierarchy to the pins of the sub-cells placed in the layout?
Chris
  • ColinSutlieff
    ColinSutlieff over 10 years ago
    Hi Chris,
    The closest command is "Place->analog->adjust cell pins"
    This command will put the top-level pin directly on top of an instance pin.
    But if the top-level pin is connected to multiple instance pins then the top-level pin will be placed at an equal distance between all the subcell pins..
    Hope this helps
    Colin
