  3. abstract generator: LEF does not contain ANTENNAGATEARE...
  • Views 17347
abstract generator: LEF does not contain ANTENNAGATEAREA
jsundermeyer
jsundermeyer over 10 years ago
I am trying to generate a LEF from Layout with antenna information with Cadence abstract generator.
Pins and metal area on pins work fine but neither gate area nor diffusion area are extracted.
Any hints on where to change something ?
  • Marc Heise
    Marc Heise over 10 years ago
    Hi Jan,
    there are many settings and options to consider and it is pretty hard to tell where it goes wrong for you without seeing the data.
    Did you check the step by step tutorial in the docu? We have a small example database in the software installation you can run through
    which might answer your questions or at least will help to ask more specific questions.
    Search for "abstract tutorial" in cdnshelp (Should find it in the AG User Guide) and it will direct you to the database and step you through it.
    Kind regards,
    Marc
  • jsundermeyer
    Okay, I have executed the tutorial. Now my extraction seems to work. I assume that I missed the declaration of the poly layer in combination with the connectivity info. Thanks, Jan
