  3. How to plot something vs Vov
  • Views 20430
Pyroblast
Pyroblast over 10 years ago
Hi guys,
I am exploring the gm/id methodology.
It happens that I managed to plot gm/id vs vgs and now I would like to plot the gm/id vs vov. I tried plotting by using the calculator but I didn't get a proper result.
Then I thought that I could plot the Vdsat vs Vgs and from here try to use some cadence feature to plot the gm/id vs Vdst.
I don;t know if Vdsat is the same as Vov. Can someone confirm? Is that the correct way to do it?
What can I do plot then gm/id vs Vdsat?
Regards.
    I'd not come across the term Vov before (even in my life as a designer) but a bit of light googling shows that it's Vgs-Vt - which is not the same as Vdsat (this shows up in a search for "vov voltage" too). You have vth in the operating point parameters (of bsim4 at least, as you do vgs and vdsat) so w bit of computation would allow you to plot gm/id vs (vgs-vth).
    It's amazing what Google can find...
  • Pyroblast
    Hi Andrew, thanks for the reply.
    So you're suggesting to use the Vgs and Vth, from the (giving this info now) operating points saved into a file? Basically then I will have to plot the Vgs vs Vgs and the Vth vs Vgs and then compute with the calculator Vgs - Vth? The testbench can be a simple diode connected mosfet with Vgs = Vds and sweep that parameter?
    I've been told that there a lot of discussions and opinions about the Vdsat vs Vov. I have read that the Vov in small channel devices is basically equal to Vdsat. But I've heard different opinions.
    Are you able to give me some enlightenment about this?
    If you're sweeping Vgs, then you could just calculate xval(Vth)-Vth (or xval of anything from the dc sweep; this will give you the x-axis of the sweep versus itself).
    Since I've never come across Vov until I did a Google search the other day, I'm not particularly well placed. However, I would trust Geoffrey Coram's response in this thread (he would know these things) that Vdsat being similar to Vgs-Vth was probably an approximation from some very old and much simpler device models that doesn't hold true in anything recent.
  • Pyroblast
    HI Andrew, thanks for the reply. That's a nice tip! The xval function. Never used before ;)
