  3. Using a DC operating point as parameter
  • Views 17758
Ron M
Ron M over 10 years ago
Just wondered if there is an easy solution to this that does not involve using skill/ocean.
We are running a DC analysis and would like to use a transistor operating point (in our case 'gm') as a parameter to next AC/RF analyses.
In the past we designer just ran a DC in certain condition (PVT/mode) and set the value manually assuming it will be good enough for all other conditions.
Now, we are more sensitive to this parameter and would like to set it up separately for each condition.
Did someone do something like that? Do you an idea how to do it?
Ronen
    Hi Ronen,
    I'm not sure what your question means? If you run a dc operating point and the conditions are the same as for the subsequent AC analysis, then the gm would be the same. For an RF analysis, I'm not sure what this would mean - because the gm would probably be time-varying.
    You can't set the gm on a device anyway - so I really don't understand what you're trying to do here.
    Kind Regards,
  • Ron M
    Let me elaborate:
    Next to a transistor, we have an additional model that includes a resistor. This resistor resistance is defined as a function of the transistor gm at DC.
    Currently the designer is running a single DC analysis in ADE, displays the gm and set the resistor accordingly. This resistor is used afterwards for all analyses.
    In our current methodology the designer uses the same resistor for all PVTS/modes (for example when running in ADEXL).
    This is not accurate enough for our next project. We would like to find a way to update this resistor before each PVT/mode.
    BR,
    Ronen
    Hi Ronen,
    The simplest way to do this would be to have two tests. The first test runs the DC analysis and measures the gm (which you should be able to retrieve using a calculator function such as OP("/M0" "gm") and have as a named output (called, say M0_gm), or even to calculate the resistor value you need to compute. The second test has a variable on the resistor, and then sets that (as a global variable) using calcVal("M0_gm" "firstTestName") - you can drag the output to the global variables and it will fill this in for you.
    It can also be done with "pre-run scripts" but I think two tests with a relationship between them would be simpler.
