  3. ADE XL - Save Netlist in different location from result...
  • Views 2326
ADE XL - Save Netlist in different location from results
Michele Ancis
Michele Ancis over 10 years ago
I take it from here that one can set some environment variables to indicate where he/she wants to save the 3 basic types of ADE XL data.
Following the information in the link, it looks to me as if netlists are tied to the same directory where waveforms (.PSF and the like) reside.
Is it possible to change this behaviour, and specify two different places for results and netlists?
Reason: the drive space where my sim results reside is periodically wiped-off. This is OK to some extent, but I woud like to at least keep information of the exact netlist that was simulated ad which point in time.
Michele
    Hi Michele, I don't think this is really possible. I filed an enhancement request recently which was to ask for the ability to do RMB->Delete results but retain netlist over the history, which was for similar motivations but not quite what you're asking for. Probably needs an enhancement CCR being filed. Regards, Andrew.
  • Michele Ancis
    Hi Andrew
    thanks. I understand that what I asked is not really implemented at the moment.
    I found a "workaround" however, which is to launch a small script which saves netlist, results and simulation script whenever I want to "snapshot" a certain situation.
    This is more than enough for my purposes.
    Michele
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    My idea was to automatically save a snapshot config to the ADEXL history together with the simulation setup and the results. As a first step towards that goal, there is CCR 1544110 requesting a SKILL function for creating a snapshot config. So, you are not alone with your desire to save information about the circuit configuration to the ADEXL history together with the simulation setup and the results.
  • Michele Ancis
    Hi Frank
    yes, I can imagine. Actually, after a period of settlement, I was fairly happy with the History mechanism, although as you say it doesn't tell you straight away your setup.
    The game changer for me was the fact that my Company stores simulation results in a NO_BACKUP area and those get wiped off with no further notice.
    I lost quite a bit of stuff thanks to this.
    Plus, the *.rdb files are stored elsewhere (basically with the cell view) and they don't get erased...
    I'm no coder but I hammered together a few functions and now I save the netlist, the oceanscript and the results in a "safe harbour" together with timestamp and the like.
    That's not elegant but is working fine for me.
    Cheers!
    Michele
