  3. hbnoise
  • Views 14962
hbnoise
curt444
curt444 over 10 years ago
How can the amount of output data stored be reduced/limited? Have tried options "lvl" and "lvlpub" with 0 and 1 settings and there is no change from the default.
    Do you by any chance have the Noise Separation option turned on? If so, that assumes that since the goal is to find out more about the noise contributions, you want to actually save all the noise contributions and ignores the save=lvlpub nestlvl=0 setting.
    With that turned off, I was able to set save=lvlpub nestlvl=0 either globally (on the Save All form) or on the analysis options - both worked.
  • curt444
    Thank you Andrew, that was it. Able to save selected nets hbnoise results now. Best regards.
