  3. How can I create synchronized clones?
  • Views 18199
213kkw
213kkw over 10 years ago
Hi all
I want to create a synchronized clone family,and i chose generate clones,then I chose create clones as synchronized familiy in create options.but the new generated clone is still not synchronized.It looks like the new generated clone is just copyed and corresponded to schematic.
It's so wierd.It happend only once ,I created synchronized clones before and this time it looks no diffrence in set up.i still can create synchronized copy by the way ,but just cannot create clone.
Dose anyone face the same problem before pls help,thank you
    Maybe the parameters are not the same? If you pick the "exact parameters" switch on the clone form does it still find the targets?
  • 213kkw
    Hi Andrew.
    thank you for the reply.
    The parameters are the same,and I picked "exact parameters" already,it can find targets but just not as synchronized family,looks like they are still free objects.i'm quite sure i already chose create clones as synchronized family.I just found out that i can still create clones successfully in another layout,so it looks like this just happen with that specific schematic
    I suggest you contact customer support so that we can take a look with you at your problematic design to see if we can figure out why the cloning isn't producing synchronous clones in this case.
  • 213kkw
    Thank you
