  3. Monte Carlo simulation issues
  • Views 15611
saikatc
saikatc over 10 years ago
I have run Monte Carlo simulation on a schematic to see the variation of propagation delay. I have used the following details for the monecarlo settings.
Statistical Variation: All
Sampling Method: Random
Number of Points: 200
Target Yield: 99.73%
Probability (1-alpha): 95%
After running the simulation I see that the delay value is same all throughout the simulation. So there is no variation of the delay. This looks strange. For the corners, I didn't change anything as the option could not be changed.
Please help me to understand how to solve the issue.
Regards
Saikat Chatterjee
    Hi Saikat,
    Several questions:
    1. What is your expression for measuring the delay (please post the exact expression)?
    2. What IC subversion are you using? (Help->About in the CIW will tell you the subversion)
    3. What PDK are you using?
    You really didn't provide enough information as to what is going on here.
  • saikatc
    Thanks a lot for your reply. I managed to proceed further. I am using Virtuoso 6.1.6-64b. The corner file needed to be edited to toggle the value of lvt_dev.
    I ran monte carlo simulation with TT corner. Unfortunately for other corners I am not able to change the corner value.
    Saikat
