  3. [Virtuoso] Weird issue with netlist generation
  • Views 18470
stanzani
stanzani over 9 years ago
Hi there
I am trying to generate a system verilog netlist netilist and the netlister is istantiating a component with the wrong port order. Wrong meas tha port of a module m0 with portlist (a,b,c) is connected as m0 i_im0(x,y,z) while I would have expected (expectations come from the schematic) m0 i_m0(y,z,x) (I am trying to make things simple, hope this is clear)
Question is: where the netlister get the information on ow to associate the port order to the higher level nets?
As s side comment I was always be unpleased about the positionalport assignment from this kind of tolls: explicit assignment would have been better, at the expense of a little bit more dis=k space ...)
Thanks muc
    A few questions:
    1. Which version of the IC tools are you using (Help->About)?
    2. Is it the System Verilog or NC Verilog netlister you're using (how did you launch it)?
    3. On the netlister options, do you have netlist explicitly enabled?
    4. Is this a leaf cell - in other words is m0 a schematic inside virtuoso, a systemVerilog or verilog text view inside virtuoso, or an external verilog/system verilog view?
    If everything is internal, the portOrder shouldn't really matter; the portOrder should only be relevant if it's a leaf cell as far as the netlister is concerned and you're referencing an external netlist. In that case, you can open the symbol and use Edit->Properties->Pin Order.
  • stanzani
    1. IC6.1.6-64b.500.14
    2. System verilog netlister
    3. it is enabled but does not work
    4. not a leaf cell: there are 4-5 level of hierarchy below
    thanks much
  • alin mocanu
    alin mocanu over 9 years ago
    On number 3, i dont see in ADE that option, how can i select "explicit netlist"?
    Assuming it's AMS as the simulator (or rather "ams"), and you're using OSS or UNL as the netlister, this would be Simulation->Options->AMS Simulator, then the Netlister tab, and then there's the "Port Connection By" option which can be set to "name" (i.e. explicit) or "order" (i.e. implicit).
  • alin mocanu
    Thanks, In the end it was a bus on the symbol that was splitted and in this way the explicit was is skipped.
    BR,
    Alin
