  3. VPRBS Source
  • Views 22969
VPRBS Source
BrJaWr
BrJaWr over 9 years ago
Is there any documentation on the vprbs source?  I'd like to understand better how to set the register length.  The LFSR mode seems like it would set the length but the length of the seed doesn't always seem to match.
  • chanakaya
    chanakaya over 9 years ago
    You can do the following at the terminal.
    > spectre -h vsource
    search for prbs.
    Also if you have access to Cadence support, you can use the following links
    support.cadence.com/.../cos;src=pubs;q=/analoglibref/analoglibref6.1.5/independent.html#vprbs
    support.cadence.com/.../cos;src=pubs;q=/spectreRF/spectreRF14.1/Chap8.html#prbs_source
    -- ajish
