  3. How to add Pwr sensitivity to a bus
  • Views 15216
mbugbee
mbugbee over 9 years ago
Using cadence_ic 6.1.6.500.14 I can successfully add Pwr Sensitivity and Gnd Sensitivity to single pins.
However adding Pwr/Gnd Sensitivity to a bus does not work.
I can set the attributes in the properties form, however the value is never kept.
When setting the attribute in the Property editor the value set is immediately cleared.
How can Pwr/Gnd attributes be set for a bus ?
e.g. trim<4:0>
  • mbugbee
    How should pwr / ground attributes be set of bus pins ?
    e.g. trim<5:0>
    This is currently not possible. Part of the work was done a little while ago to partly allow it in the underlying infrastructure, but it has not yet made it all the way through to the schematic editor. There is an existing CCR, 896647, with numerous duplicates. You may want to contact customer support about this so that a duplicate CCR can be filed on your behalf to capture your requirements and to allow you track this.
    Kind Regards,
