  3. Error message: port cannot be drained
  • Views 15651
PatrikOsgnach
PatrikOsgnach over 9 years ago
Since a few days I have this error message appearing in my CIW:
*Error* drain: port cannot be drained - port: /var/tmp/saved-design-variables4
this happens when I type this in the CIW:
(simulator 'spectre)
but not always, so it is hard to reproduce the problem. The only reference I found is here and speaks about disk usage, but the usage of the volume containing /var/tmp is about 35%.
The last digit of the file may change but it is always related to a file which I do not own and has 0 bytes size.
Any idea about how I can track the root cause?
Thank you and best regards,
Patrik
  • PatrikOsgnach
    OK, forgive me. I didn't notice that, on some of our nodes, /var is on another partition, which was full
