  3. probe different point on power nets in av_extracted vie...
  • Views 15876
probe different point on power nets in av_extracted view
primemath
primemath over 9 years ago
In my design there are multiple hierarchy and i have done the av_extraction at the top level now i want to power net at the lowest level but i am not able to do so can you pls guide me on how to do so.
I am using  virtuoso 6.1.6-64b for av_extraction and ultrasim 2016 for simulations.
Priyankar
    Priyankar,
    The simplest way to do it is to probe the nets in the same way you would normally, but instead of descending into the av_extracted view, go into the corresponding schematic view. If you click near the pin of a device (not on the pin, as that will probe the current) on the power net you're interested in, it will then allow you to plot the power net where that device connects to it. Alternatively, you can also click on the nets in the extracted view, but that's sometimes quite hard (and depends on whether the extraction points are selectable). You could use the navigator in the extracted view to do this though (I think - although that might depend on using a recent enough version).
  • primemath
    Andrew,
    I have done the av_extraction of my chip now when i am simulating it using ultrasim and trying to probe that vdd net (**:VDD) connected to transistor source i am observing it as an ideal supply (no droop) observed. So i wanted to know what is the right way to do the "power net" extraction and how to probe the power net close to the source of the transistor.
    Priyankar
