  3. Injecting a device into an existing net
  • Views 15747
ChrisEAS
ChrisEAS over 9 years ago
I am looking for a way to inject a voltage source (or a resistor etc.) into an existing net. My goal is to manipulate the voltage on the net, e.g. changing the threshold voltage of a MOSFET by injecting a vsource between gate an net connected to it. One solution I can think of is changing the schematic using Skill code - but I would like to avoid that. Another option is to modify the Spectre netlister, which basically works but feels too much of a hack to me.
Is there another, minimally intrusive way of achieving the same thing? E.g. some Spectre solution like alter statement or alike? Ideally I would like to create Spectre code which can be simply included into the existing and unchanged netlist.
Thanks and best regards,
Christoph
  • ChrisEAS
    I think I found a possible solution in this thread:
    community.cadence.com/.../21166
    The trick is to overwrite the instance the net is connected to and replace it with a macro device containing the source I want to inject. MOSFETs are usually defined with by a subcircuit. Using the Spectre option "duplicate_subckt=ignore" I can redefine this subcircuit and inject the vsource at the gate.
    Please still let me know if there is better option.
    Best regards,
    Christoph
  • skillUser
    skillUser over 9 years ago
    Christoph,
    you might also try looking at the 'nodeset' feature that Spectre has available? Not sure if this is what you are looking for, but I thought it was worth mentioning. Best regards,
    Lawrence.
  • ChrisEAS
    Thanks for the hint, Lawrence. I am afraid nodeset is not what I am looking for. It provides a way to specify an estimate of the solution, similar to initial conditions. What I am looking for is a way to manipulate the topology.
    Best regards, Christoph
    Hi Christophe,
    That's pretty much what I was going to suggest.
  • ChrisEAS
    Thanks, Andrew. The only problem with this approach is that the original definition of the subcircuit seems lost once it has been redefined. Or is there a way to access the original definition?
    Christoph
