  3. Cadence Liberate: Path delays all zero in exported of verilog...
  • Views 18136
Cadence Liberate: Path delays all zero in exported of verilog models
marten
marten over 9 years ago
Hi there,
I characterized custom cells for different corners and now want to create a verilog model for each corner. Although timings in the *.lib-file are totally different, path delay in all verilog models stay zero.
Here are the steps I did to create the models:
liberate > read_library lib/SUBVT28CORE_1.0_1.0_0_0_25_ecsm.lib
Command line arguments: none.
ALTOSHOME set to '/sct/homes3/cadence/liberate-15.14hf070'.
Server ID : T20170228092209088037S0008335
Reading 'lib/SUBVT28CORE_1.0_1.0_0_0_25_ecsm.lib' ...
//LIBERATE parameter "enable_command_history" set to "0"
LIBERATE parameter "slew_lower_rise" set to "0.3"
LIBERATE parameter "slew_lower_fall" set to "0.3"
LIBERATE parameter "slew_upper_rise" set to "0.7"
LIBERATE parameter "slew_upper_fall" set to "0.7"
LIBERATE parameter "measure_slew_lower_rise" set to "0.3"
LIBERATE parameter "measure_slew_lower_fall" set to "0.3"
LIBERATE parameter "measure_slew_upper_rise" set to "0.7"
LIBERATE parameter "measure_slew_upper_fall" set to "0.7"
LIBERATE parameter "delay_inp_rise" set to "0.5"
LIBERATE parameter "delay_inp_fall" set to "0.5"
LIBERATE parameter "delay_out_rise" set to "0.5"
LIBERATE parameter "delay_out_fall" set to "0.5"
Library read successfully.
1
liberate > write_verilog my.v
Writing Verilog to my.v
Writing Verilog for cell INV_X1
Looking at my.v gives:
// type:
`timescale 1ns/10ps
`celldefine
module INV_X1 (Z, A);
        output Z;
        input A;
        // Function
        not (Z, A);
        // Timing
        specify
                (A => Z) = 0;
        endspecify
endmodule
`endcelldefine
Instead of the timing specification, I would expect something like this (example from 65nm lib):
   specify
     // delay parameters
     specparam
       tpllh$A$Z = 97:97:97,
       tphhl$A$Z = 74:74:74;
     // path delays
     (A *> Z) = (tpllh$A$Z, tphhl$A$Z);
   endspecify
Why does liberate skip the timing annotation?  Am I missing out some necessary configuration?
Thanks in advance and best regards,
Marten
    I suggest you contact customer support for this question.
  • marten
    As a university customer support is not part of our contract... :-(
    Maybe you can give some hints? Should there be a delay writen in the verilog models or does timing get annoted after aplying a sdf file (post-synthesis)? Maybe SDF is sufficient then?!
    Are you part of the Europractice scheme? If so, you can get support via Europractice. If you're not part of Europractice, then usually support can be channelled via your contact point within your University. Some details can be found at:
    I don't spend that much time on Liberate myself, so I'd have to sit down and research this in more detail; because I answer questions in here in my spare time, and I really don't have any this week, I don't have the bandwidth to research and answer your question (if it had been something I could answer quickly, I would have done that already). Maybe somebody else will be able to, but we don't get a great number of Liberate questions on the forums...
  • marten
    nevermind. Yeah I am wondering why so few questions about liberate are around here...
    I guess then I will have to contact europractice. Thank you very much for your effort.
    I'd have loved to have helped - just a bit constrained at the moment! The day job keeps getting in the way ;-)
  • marten
    Nevermind Andrew, I only know a few ambitious forum moderators and one of them is you ;-)
    Besides, I could solve the problem:
    write_verilog -specparams -table-style min-avg-max my.v
    enables the desired behaviour. Neverthless, these results in optimistic/pessimistic timing models, so anotating an SDF is preferable for more accurate timing simulations.
