  3. Extracted Netlist Simulation Speedup?
  • Views 15440
MMueller
MMueller over 9 years ago
I have a config view with verilog on top and an av_extracted view as an instance in it. I am using the UNL flow out of ADE Assembler (using newest tool versions).
The av_extracted cellview is about 200MB in library manager...and the "netlisting" (the time when simulation is started from ADE until irun is called) takes about 7 hours!
When i netlist only the av_extracted with ADE L (not using UNL) it takes about 10 seconds...Is there a possibility to speed up the "netlisting" of the extraced view from ADE Assembler in UNL flow? What happens during this time?!
I am already using
envSetVal("adexl.test" "checkForNewCellviewVarsUponRun" 'cyclic "No")
envSetVal("adexl.test" "checkForUnsavedViewsUponRun" 'boolean nil)
envSetVal("adexl.gui" "disableConstraintsRead" 'boolean t)
as suggested....
Best regards,
Markus
  • ychang
    ychang over 9 years ago
    Hi, Markus,
    I also have the same issue, it seems only one core can be used during netlist.
    Best Regards,
    Ychang
    Could both of you please contact customer support about this? We need to understand the nature of your data, because the performance should not be at this level.
