  3. Cell only in schematic but not layout
  • Views 15285
itos
itos over 9 years ago
Is is possible to have a cell that only exists in the schematic but not in the layout and still have it LVS clean?
I give one example where I know that it works: noConn from basic.
I give a couple of examples where I would fine this useful:
1.) I created a "wire_model" cell that just implements first order parasitic estimations for long wires in my model. For Layout (incl parasitic extraction) this should just be replaced by a short.
2.) I have some dummy connectors which just route one pin to another. To avoid warnings and errors I just place a 0 Ohm resistor or a vdc with 0V in between. Clearly this should be ignored in layout because there is an actual wire
3.) My standard cell inverters have "output" as pin type but I need them to connect in parallel to achieve my desired strength. For example, I would have INV1<1:2>, INV2<1:10> etc.  In order to evoid warnings, I can also place them individually in the schematic and put a res with 0 Ohm between the outputs.
Thanks!
  • Quek
    Quek over 9 years ago
    Hi itos
    Yes, it is possible. E.g. you can use the following cmds if you are using PVS:
    lvs_black_box wireModelCell -source
    lvs_filter_device wireModelCell -source -short PLUS MINUS
    Best regards
    Quek
