  3. Loading Default setting in cds initalization
  • Views 15480
wgtkan
wgtkan over 9 years ago
Every time, I want to launch virtuoso cadence, I source my settings by typing the following command in my terminal: source /apps/settings
Then virtuoso
How do I be able to load my default settings in my .cdsenv or .cdsinit?
I want to start virtuoso without typing source/ apps/settings every time to launch virtuoso
  • Quek
    Quek over 9 years ago
    Hi wgtkan
    Instead of using .cdsinit file to do the loading, it might be more appropriate to load the shell settings through an alias. E.g. add the following line in your .cshrc file:
    alias myVirtuoso "source /apps/settings; virtuoso &"
    You can then start Virtuoso using "myVirtuoso".
    Best regards
    Quek
