  3. Using AMS pads on Virtuoso Layout L
  • Views 15137
dpalomeq
dpalomeq over 9 years ago
I am trying to include AMS pads (process AMS C35B3C3) in my layout but I am getting the BAD_SUBSTR_SUBTAP_FLOAT_ERC error when running Assura DRC. Regarding the pins, I am using the PIN PAD layer and I am naming the power and ground pins "vdd3r!" and "gnd3r!", respectively.
Why am I getting this error?
Thanks in advanced!
David.
    David,
    You should include the specific AMS process variant you're using - maybe somebody familiar with that process will be able to advise you. I'm not, so I can't, but others might if you give them enough information.
    Kind Regards,
