  3. guide needed for simulating the circuit with script
  • Views 19781
rockyicer
rockyicer over 9 years ago
hello, guys,
    I used to simulate the analog circuit by clicking the GUI provided by IC616 and mmsim14.  I find it's such a burden to simulate the same circuit for so many times. for example, if I design a specified OTA including only 9 mosfets and 2 capacitors. I have to adjust the dimensions for uncountable times to find  good ones, especial for a optimal one(e.g noise optimation).
Now I want to do this in an automated way. I want to write the scripts in order to let the program calculating the proper bias voltage and mosfet and passive elements dimensions for me with the optimization method I give. Here is problem: where can I find the materials that could guide me to learn the scripts language(I know there is pspice)?  I hope this language could allow me to call the simulator(like mmsim14) to do the needed simulation such as DC AC STB PSS etc.... and return the simulated results to the specified directories. and then I could transfer these results to the python scripts that I write to find the optimal values. Or a better situation is I could use the functions(e.g: find the maximum point of a simulated line such as gm/ID line or find the point corresponding to maximum slope rate) provided by the IC616 Platform(I believe it's exist in the waveform tools, but how do I call these functions?) instead of using the python scripts.  For a single simulation, maybe the result is not the optimal one, so I need to call the simulator to do the former simulation again if the current values don't meet my targets values until I find the optimal one( the ones that meet my targets values).
I have the systemic design methodology. Could anyone give me some links(including the RAK or documents) or the name of the pdfs in the IC616 doc files which could guide me to learn the appropriate language to describe the detailed circuits and call the ADE simulator and do the Loop to find the target values?
forget to mention: I use tsmc technology so I do have all the model files used by spectre.
thans in advance!
    You can do this using OCEAN - so I suggest you read the OCEAN reference manual. This contains the functions to define what you want to simulate, and to post-process the results, and then because it's SKILL you can have loops to simulate, post-process, adjust and re-simulate until your goals are met.
    However, you could just use the Optimiser (local or global) that is available in either ADE GXL or ADE Assembler, rather than writing your own...
  • rockyicer
    Dear Andrew Beckett:
    thanks for your help. I am using the TSMC65nm_gp technology and the model uses BSIM4.5 version. Now I need to know the small signal equivalent circuit(SSEC) coresponding to the standrad 1.2V nch/pch(it's a regular digital mosfet not RF mos).  the soft is IC616 and MMSIM141
    I almost find every doc that I could access and find the equivalent circuit for bsim4 below at $MMSIMHOME/doc/spectremod/spectremod.pdf  page 1250:
    After I simulated the dc operation, I could read the model parameter like this:
    signal OP("/M0" "??")
    beff 22.98m
    betaeff 14.4m
    -b------------------------------
    cbb 2.198f   Total bulk capacitance intrinsic, overlap and fringing components
    cbd -6.257a
    cbdbo -6.257a
    cbg -2.724f
    cbgbo -2.724f
    cbs 532.2a
    cbsbo 532.2a
    -d-----------------------------------
    cdb -5.267a
    cdd 1.25f   Total drain capacitance intrinsic, overlap and fringing components
    cddbo 22.14a
    cdg -1.264f
    cdgbo -36.51a
    cds 19.64a
    cdsbo 19.64a
    -g------------------------------------
    cgb -363.1a
    cgd -1.234f
    cgdbo -6.279a
    cgg 17.26f    Total gate capacitance intrinsic, overlap and fringing components
    cggbo 14.79f
    cgs -15.66f
    cgsbo -14.42f    CGSBO = -dQg/dVs intrinsic gate-to-source capacitance
    -s---------------------------------
    csb -1.83f       Intrinsic source-to-bulk capacitance
    csd -9.606a    Total source-to-drain capacitance cds 19.64a
    csg -13.27f
    css 15.11f     Total source capacitance intrinsic, overlap and fringing components
    -----Junction diode model parameters
    cjd 1.872f   Zero bias drain bottom junction capacitance per unit area.
    cjs 3.605f
    -----------------overlap cap
    covlgb 0
    covlgd 1.227f
    covlgs 1.239f
    I can't find the corresponding cds/cdsbo(such as cdsi) in the above small signal equivalent circuit(SSEC). but I think the SSEC should include cds which is quite important.
    And also, cjd stand for Zero bias drain bottom junction capacitance per unit area. but the voltage across the drain and bottom(bulk terminal) is not Zero. how could I evaluate the real drain bottom junction capacitance since the dc operation info don't give me other information?
    so I wonder if I find the right SSEC? if not, please tell me where I can find the right SSE circuit that could match the dc operation information.
    Why do you need this? The linearised circuit is used inside the simulator for doing things like ac analysis - and the values output by the model in the operating point analysis are generally output for user understanding, not to allow you to plug them in to your own small-signal equivalent circuit. There may also be operating point parameters that are output that aren't directly used in such a small-signal model.
    Put another way, this is an implementation detail within the bsim4 model. You could consult the bsim4 web page on the University of Berkeley for more details.
