  3. stitching results of two transient simulations
  • Views 17786
SoniaMK
SoniaMK over 8 years ago
This might be a simple question for those who are skilled in spectre but it seems I can't figure out how to do the following. I want to run two transient simulation, the second one starting from a point in time where the first simulation finished or perhaps at a point of time somewhere during the run of the first simulation. Then I would like to stitch together the results of the first and second simulation. I hope this is possible and going from the first to the second simulation can be done quite seamlessly.
Thanks for your help.
    There's an option on the direct plot form (Results->Direct Plot->Main Form) for transient to allow you to reference a previous result and stitch that together. However, this only offers the ability to do it for two results.
    Alternatively you can use this SKILL code to concatenate a number of waveforms:
    /* abConcatWaveforms.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 08, 2009
    Modified   Jan 12, 2009
    By         A.D.Beckett
    Function to concatenate waveforms.
    For example:
    new=abConcatWaveforms(flip(sig) sig)
    will produce a new waveform made out of a flipped version of
    the input signal, glued to the original input signal.
    Copies units and name attributes from the first x and y vector it can find
    them on. Other attributes (e.g. expression) are ignored, because they're
    unlikely to be valid for the concatenated waveform. Also copies plotStyle,
    xScale and barBase waveform attributes.
    Can also register as a special function:
    abRegConcatWaveformsSpecialFunction()
    This will add abConcatWaveforms as a calculator special function.
    SCCS Info: @(#) abConcatWaveforms.il 01/12/09.10:29:05 1.2
    *             (abConcatWaveforms (wave1 [waves...]))             *
    *  Function to concatenate a number of waveforms. The function   *
    *   takes an arbitrary number of waveforms (assumed to all be    *
    *  waveforms or families of the same number of dimensions), and  *
    * concatenates the axes together. Note that care should be taken *
    *  if the x-axes overlap, because this merely concatenates the   *
    *              vectors without any checking at all.              *
    (defun abConcatWaveforms (wave1 @rest waves)
      (let (xVec yVec newX newY newLen len xName xUnits yName yUnits
                 newWave (attribs (makeTable 'attribs nil)))
        (cond
          ((drIsWaveform wave1)
           (setq newLen (drVectorLength (drGetWaveformXVec wave1)))
           (foreach wave waves
                    (setq newLen (plus newLen
                                       (drVectorLength (drGetWaveformXVec wave))))
           (setq newX (drCreateVec (drGetWaveformXType wave1) newLen))
           (setq newY (drCreateVec (drGetWaveformYType wave1) newLen))
           (foreach wave (cons wave1 waves)
                    (setq xVec (drGetWaveformXVec wave))
                    (setq yVec (drGetWaveformYVec wave))
                    (setq len (drVectorLength xVec))
                    (for pos 0 (sub1 len)
                         (drAddElem newX (drGetElem xVec pos))
                         (drAddElem newY (drGetElem yVec pos))
                    ; Record attributes
                    (unless xName (setq xName (getq xVec name)))
                    (unless xUnits (setq xUnits (getq xVec units)))
                    (unless yName (setq yName (getq yVec name)))
                    (unless yUnits (setq yUnits (getq yVec units)))
                    (foreach attrib '(plotStyle xScale barBase)
                             (unless (and
                                       (arrayref attribs attrib)
                                       (get wave attrib))
                               (setarray attribs attrib (get wave attrib))
           ; Store found attributes
           (when xName (putpropq newX xName name))
           (when xUnits (putpropq newX xUnits units))
           (when yName (putpropq newY yName name))
           (when yUnits (putpropq newY yUnits units))
           ; Finally create the new waveform
           (setq newWave (drCreateWaveform newX newY))
           (foreach attrib attribs
                    (putprop newWave (arrayref attribs attrib) attrib)
           newWave
           ) ; is waveform
          ((famIsFamily wave1)
           (apply 'famMap (constar 'abConcatWaveforms wave1 waves))
           ) ; is family
          (t
            (error "abConcatWaveforms - can't handle %L\n" wave1)
          ) ; cond
        ) ; let
      ) ; defun
    *              (abConcatWaveformsSpecialFunctionCB)               *
    *  Callback function for the abConcatWaveforms special function   *
    * Just takes the buffer and one stack item and concatenates them. *
    (defun abConcatWaveformsSpecialFunctionCB ()
      (calSpecialFunctionInput 'abConcatWaveforms '(STACK))
    *              (abRegConcatWaveformsSpecialFunction)               *
    * Register abConcatWaveforms as a special function. Note that this *
    * only uses abConcatWaveforms with two arguments - otherwise would *
    * need a form to indicate how many values to concatenate - so this *
    *                         keeps it simple!                         *
    (defun abRegConcatWaveformsSpecialFunction ()
      (calRegisterSpecialFunction
        (list "abConcatWaveforms" 'abConcatWaveformsSpecialFunctionCB))
      t
  • SoniaMK
    Thanks, Andrew, for the reply. Stitching the results was actually only half of my question. Equally important is how to run a second simulation from the time and state the first one stopped at and not having the second one start from time 0 and also not modifying anything in the testbench. Is it possible? Can you help with this?
    There are transient options called savefile, savetime, recover etc which do the job:
    22      saveperiod        Save the tran analysis periodically on the simulation
                              time.
    23      saveperiodhistory=no
                              Maintains the history of saved files. If yes,
                              maintains all the saved files. Possible values are no
                              and yes.
    24      saveclock (s)     Save the tran analysis periodically on the wall clock
                              time. The default is 1800s for Spectre. This
                              parameter is disabled in the APS mode by default.
    25      savetime=[...]    Save the analysis states into files on the specified
                              time points.
    26      savefile          Save the analysis states into the specified file.
    27      recover           Specify the file to be restored.
    If you run the first simulation with a savefile, and either savetime or save period or save clock to specify how often you want to write it, and then on the second simulation reference a file using recover, it will do what you want.
