  3. problem simulating a sub-circuit (spectre model) with a...
  • Views 17500
problem simulating a sub-circuit (spectre model) with ade
asetji
asetji over 8 years ago
I have a spectre model for a layout only component (no netlist) and I want to simulate it along with my rest of the circuit.
I followed the guidelines in "https://community.cadence.com/cadence_blogs_8/b/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade"
in which i created a symbol, copied the symbol view to spectre view and modified the cdf for the block/sub-circuit.
Now, when I instantiate the block in my testbench where it is connected to other blocks and components from analogLib, the simulation fails at the netlist level with the following error
Begin Incremental Netlisting Sep  5 15:39:23 2017
*Error* eval: unbound variable - simVerilogFlattenBuses
End netlisting Sep  5 15:39:23 2017
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful.
However, if i remove all the other components except the block from my testbench then simulation passes, ofcourse the simulation itself is meaningless but aleast it generates the netlist with my component displayed as below
I2 (net3 net2 net01) test_bp
Can someone shed some light on what I am doing wrong?
BR
    If the error is related to simVerilogFlattenBuses, that's a bit strange. I found a few cases on this, but the reasons aren't that clear - I think the best thing to do is to contact customer support so that we can look at your setup.
  • asetji
    thanks. I will first confirm with my supervisor before posting on support.
    One thing I did notice was that after getting the above mentioned error, even my normal test benches which had nothing to do with the subcircuit started giving the same error and I had to eventually restart virtuoso. I haven't tested my original sub circuit after restarting though.
  • asetji
    seems like I cannot post it to the support because of the university support agreement.
