  3. VerilogA vs. built-in device models
  • Views 15413
samer1
samer1 over 8 years ago
I've been using verilog-A to model devices for quite sometime and I wanted to ask what differences are there between the user define model (written in verilogA) and a built-in mosfet model, for example, from the simulator's perspective.
For example, I have a kit with its specific devices and their models are written in .scs file. Those files simply include the parameters passed to the model equations, I assume, that are hard coded in the simulator. On the other hand, when I write the verilogA code I define both the equations and the model parameters.
Does the simulator interpret both models the same way in terms of the numerical algorithms used (Newton-Raphson, ..etc)?
Does the simulator process the verilogA equations directly or there is some intermediate step to translate the verilogA code to another form then start solving the equations? (something like a synthesizer in digital). The reason why I am asking this question is that I read some articles about verilogA and they recommended not to overuse the verilogA functions such as ddt , for instance, to ensure proper convergence. So, it sounds to me like there is some intermediate interpretation step done by the simulator before solving the equations.
    The simulator uses the same numerical methods regardless of whether  you're using a built-in model (implemented in C/C++) or one written in VerilogA. Of course, the representation of things like ddt are converted because the simulator is essentially not truly integrating and differentiating - it's using numerical methods - but the same is true for C-level built-in models.
    The guidance you'll have seen is probably about writing good models - the difference is that Verilog-A gives non-expert modellers quite a bit of freedom to write models that will either not converge well or not converge at all, whereas the built-in models have typically been written by modelling experts with a good understanding of how something can be solved numerically. There's plenty of guidance out there on how to write good behavioural models, including training classes available from Cadence (see the Services->Training menus at the top of the page).
  • samer1
    Got it.
    Thanks Andrew
