  3. virtuoso won't start -- core dumps
  • Views 4286
KKimber
KKimber over 8 years ago
We had a Linux maintenance down over the weekend.  Linux severs were patched as part of the maintenance down.  checkSysConf output prior to patching/maintence down is included below. A new file system was attached. Now virtuoso won't start.  Entire design team is down.  I have also filed a Cadence support request and I'm waiting for a response.
[Copyright 2002-2016] Cadence Design Systems, Inc. All rights reserved.
This program and online documentation may not be copied, modified,
re-published, uploaded, executed, or distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf: Version 3.25 ====================
Date information gathered: Thu Sep 21 15:05:22 CDT 2017
Host Name ..............: ep1p-apca04.starkey.com
Hostid .................: 280a6220
Operating System .......: Linux / x86_64
OS Version .............: Red Hat Enterprise Linux Server release 6.7 (Santiago)
Kernel Version .........: 2.6.32-573.12.1.el6.x86_64
Hardware Type ..........: x86_64
Memory .................: 128793 Megabyte
CPU model ..............: Intel(R) Xeon(R) CPU E5-2670 v3 @ 2.30GHz
No. of CPUs ............: 48
Total Swap Space........: 4095 Megabyte
X Server ...............: [ 31.174] (--) MGA(0): Pseudo-DMA transfer window at 0xC6000000
Patch Data file ........: /cad/apps/cadence/virtuoso_6.1.7.714/share/patchData/Linux/x86_64/redhat/6.0WS/IC6.1.7
**************** Now verifying configuration ****************
Validating Kernel requirements...
Minimum Installed Status Info
2.6.32-431.11.2 2.6.32-573.12.1.el6.x86_64 PASS
Validating MEMORY requirements MegaByte ...
2048MB 128793MB PASS
Validating SWAP requirements in MegaByte ...
4096MB 4095MB FAIL
Validating DISPLAY requirements...
8 planes 24 planes PASS
PseudoColor TrueColor
Validating PACKAGE requirements.....29 to check
# PACKAGE Release Build Installed Arch Status Info
1 glibc 2.12 1.132 2.12-1.166.el6_7.3 i686 PASS
-> 'GlibC'
2 glibc 2.12 1.132 2.12-1.166.el6_7.3 x86_64 PASS
-> 'GlibC'
3 elfutils-libelf 0.152 1 0.161-3.el6 i686 PASS
-> 'Libelf Library'
4 elfutils-libelf 0.152 1 0.161-3.el6 x86_64 PASS
-> 'Libelf Library'
5 ksh 20120801 10 20120801-28.el6_7.3 x86_64 PASS
-> 'ksh'
6 mesa-libGL 9.2 0.5 - FAIL Package not installed.
-> 'Mesa libGL Library'
7 mesa-libGL 9.2 0.5 10.4.3-1.el6 x86_64 PASS
8 mesa-libGLU 9.2 0.5 - FAIL Package not installed.
-> 'Mesa libGLU Library'
9 mesa-libGLU 9.2 0.5 10.4.3-1.el6 x86_64 PASS
10 openmotif22 2.2.3 19 - FAIL Package not installed.
-> 'openmotif'
11 openmotif22 2.2.3 19 2.2.3-19.el6 x86_64 PASS
-> 'openmotif'
12 libXp 1.0.0 15.1 - FAIL Package not installed.
-> 'libXp'
13 libXp 1.0.0 15.1 1.0.2-2.1.el6 x86_64 PASS
-> 'libXp'
14 libpng 1.2.49 1.el6_2 - FAIL Package not installed.
-> 'libpng'
15 libpng 1.2.49 1.el6_2 1.2.49-2.el6_7 x86_64 PASS
-> 'libpng'
16 libjpeg-turbo 1.2.1 1 - FAIL Package not installed.
-> 'libjpeg'
17 libjpeg-turbo 1.2.1 1 1.2.1-3.el6_5 x86_64 PASS
-> 'libjpeg'
18 compat-expat1 1.95.8 8 - FAIL Package not installed.
-> 'libexpat.so.0'
19 compat-expat1 1.95.8 8 1.95.8-8.el6 x86_64 PASS
-> 'libexpat.so.0'
20 libXtst 1.2.1 2 1.2.2-2.1.el6 i686 PASS
-> 'libXtst.so.6'
21 libXtst 1.2.1 2 1.2.2-2.1.el6 x86_64 PASS
-> 'libXtst.so.6'
22 compat-readline5 5.2 17.1 - FAIL Package not installed.
-> 'Readline Library'
23 compat-readline5 5.2 17.1 5.2-17.1.el6 x86_64 PASS
24 ncurses-libs 5.7 3.20090208 - FAIL Package not installed.
-> 'ncurses library'
25 ncurses-libs 5.7 3.20090208 5.7-4.20090207.el6 x86_64 PASS
26 redhat-lsb 4.0 7 - FAIL Package not installed.
-> 'lsb'
27 redhat-lsb 4.0 7 4.0-7.el6 x86_64 PASS
-> 'lsb'
28 glibc-devel 2.12 1.132 2.12-1.166.el6_7.3 i686 PASS
-> 'GlibC-devel'
29 glibc-devel 2.12 1.132 2.12-1.166.el6_7.3 x86_64 PASS
-> 'GlibC-devel'
Validating FILE existence .....0 to check
Validating NOTFILE existence .....0 to check
Configuration checks failed on this workstation (ep1p-apca04.starkey.com), status is: FAIL
This system does not have the correct packages to run IC6.1.7
Run checkSysConf IC6.1.7 -P <PACKAGE>
to find out which products require this package.
Exiting checkSysConf ... Good-bye
Output is saved as /tmp/checkSysConf.ep1p-apca04.starkey.com-2017.09.21.15:05.7823.log
    As this is being dealt with by customer support, I'm not going to answer it here to avoid double working or conflicting information. Also customer support is absolutely the right channel for critical support issues such as this. There's not enough information here anyway as knowing the checkSysConf before the update isn't that helpful, and it would be more useful to know what the error is when it fails to start. Please provide that info to customer support.
  • KKimber
    Documenting the solution. A "subversion" (SVN) version control system upgrade modified the LD_LIBRARY_PATH variable causing Virtuoso to pick up bad "/lib64" libraries which crashed Virtuoso. The fix was to remove .../subversion/lib64 from the LD_LIBRARY_PATH variable. Also, Cadence R&D is going to look at hardening Virtuoso against this type of issue.
