  3. Noise Simulation of DAC+VCO
  • Views 1515
Nitesh Tripathi
Nitesh Tripathi over 8 years ago
Hi all,
I have to do noise simulation of DAC+VCO. So I am doing Pss-Pnoise simulation. For DAC, there is witch capacitor circuit, and input of the DAC are clock signal and trim bit (according to which DAC output voltage get set). According to the DAC output voltage VCO gives a output frequency. I am confused how to do the noise simulation of this schematic and what should be the setting in the Pss-Pnoise simulation. Any lead will be appreciated. Thanks in advance.
  • Nitesh Tripathi
    Hi all,
    This problem has been solved.
