  3. Abstract generation : Warning : Design contain zero-pin...
  • Views 15759
Abstract generation : Warning : Design contain zero-pin terminal.
Anklon
Anklon over 8 years ago
I'm using Virtuoso Abstract Generator , version  IC6.1.6-64b.500.14 . When trying to run step pins for the cells, I got this warning:
> *WARNING* (ABS-12042): Cell NAND2X1: Design contains zero-pin terminals. There terminals will be deleted.
>INFO (ABS-12001): Cell NAND2X1: There are 5 existing terminals.No pins will be added for them.
>INFO (ABS-11901): Cell NAND2X1: step pin finished.
and pin checking is not successful. I checked the design couple of time and all the pins have proper terminal and pin name. I also generate abstract for INVX0 and INVX1 cells and they work out just fine.
What could be the possible mistakes here?  How could I solve this?
Thank You
  • Marc Heise
    Marc Heise over 8 years ago
    there is an article in our support database discussing this:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000005xFqPEAU&pageName=ArticleContent&sq=
    Let me know if you can't access it and I will paste some more of it here.
    Basically it says you have terminals in your layout without a physical pin shape.
    Some parts of the article:
    In IC6.1.6 and earlier releases, the warning is coming because there is some net and terminal in layout view for which there is
    no physical pin. This can be verified by interactively opening the layout design in virtuoso and calling below SKILL code in CIW:
    cv=geGetEditCellView()
    cv~>terminals~>pins
    It will show an output similar to below and will have atleast one nil in it.
    \t ((db:0x754fe120)
    \t     (db:0x754fe11e)
    \t     (db:0x754fe123)
    \t     (db:0x754fe122)
    \t     (db:0x754fe11f)
    \t     (db:0x754fe121) nil
    \t )
    It suggests that cellview has logical terminals without any physical pins. To fix such a layout you can interactively call below SKILL
    code after opening the layout in EDIT mode. It will delete such a net and terminal.
    foreach(tm cv~>terminals
                    unless(tm~>pins dbDeleteObject(tm~>net))
    And then save the layout and run a new session of Abstract Generator.
    Marc
