  3. PSTB loop-gain Phase-plot : error at lower frequency
  • Views 19261
jdp721
jdp721 over 8 years ago
Hi.
I am simulating the common-mode loop gain of common-mode feedback loop of a fully differential amplifier, through PSS/PSTB analysis (using "diffstbprobe").
But, the phase-plot obtained shows a low-freq (dc) phase of 0° (instead of 180°) !
Please see the attached screenshot - the left half phase plot is as expected (obtained from another circuit), but the right half plot seems erroneous at low frequencies as I stated above!
I am using: PSS errpreset=conservative, and reltol=1e-5, vabstol=3e-8, iabstol=1e-13.
Can you please suggest a way to obtain the actual phase plot profile from the PSTB.
PSTB plots
Thanks!
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago
    Your case might be similar to the one discussed at http://www.designers-guide.org/Forum/YaBB.pl?num=1294178255
  • jdp721
    jdp721 over 8 years ago in reply to Frank Wiedmann
    THANK YOU Frank for pointing to the relevant thread... Slight smile
    But, I am not able to locate any asymmetry in my differential circuit, as this is at schematic level, and with only single f/b loop (the CMFB loop that's having the diffstbprobe).
    Circuit is having a folded cascode amplifier followed by source-follower (in differential open-loop config), and the peculiar dc phase of 0° is coming when I am using n-MOS source-follower in place of p_MOS source-follower!
    Can it be because of testing in open loop config?
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago in reply to jdp721
    Without a detailed examination of your circuit, it's difficult to say what exactly is causing this behavior in your case. However, as discussed in the thread, it probably does not indicate a stability problem (and the thread also explains how to confirm this).
  • jdp721
    Okay...thanks Frank once again.
