  3. calibreview fatal error
  • Views 25450
CxD7
CxD7 over 8 years ago
After I use calibre PEX for extraction, and it finishes without errors, I want to import the netlist created into a Cadence schematic with calibreview. However, when I run calibreview, I get a fatal error message, telling me to  consult log file. The logfile contents are below
INFO: cds.lib has been converted to lib.defs /opt/CoE/mentorGraphics/aoi_cal_2017.2_28.22/tmp/32702_result_lib.defs
RUNNING PEX back-annotation...
//  Calibre FDI  v2017.2_28.22 Tue Jun 6 14:24:00 PDT 2017
//                  Copyright Mentor Graphics Corporation 2008-2017
//                             All Rights Reserved.
//         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//             WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//               OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Mentor Graphics software executing under x86-64 Linux
//  64 bit virtual addressing enabled
//         This software is in pre-production form and is considered to be
//         beta code that is subject to the terms of the current Mentor
//         Graphics End-User License Agreement or your signed agreement
//         with Mentor Graphics that contains beta terms, whichever applies.
//  Running on Linux engr-icms06g.catnet.arizona.edu 3.10.0-693.5.2.el7.x86_64 #1 SMP Fri Oct 13 10:46:25 EDT 2017 x86_64
INFO: Parsing command line arguments...
INFO: License checked out successfully for calibreqdb.
INFO: Parsing cellmap file...
INFO: Executing back annotation...
ERROR: Could not access LibDef plug-in for oaLibDefSystem: #4: Shared Library Not Found: Error loading library 'libddbase_sh.so'. /opt/CoE/cadence/IC617/tools.lnx86/lib/64bit/libddbase_sh.so: undefined symbol: _ZN8oaCommon11FactoryBase11getRefCountEv
It seems like there is an issue with 'libddbase_sh.so'? I assume this is a file needed by cadence? The virtuoso version is
virtuoso version 6.1.7-64b
Calibre Skill Interface * (v2017.2_28.22) *
    Since Calibre is a Mentor (now a Siemens company) product (as it says in the log file), you'd be far better off asking this to Mentor or on a Mentor forum. The product and interface code that generates the calibre view comes from them...
  • CxD7
    CxD7 over 8 years ago in reply to Andrew Beckett
    Hi, I can't seem to make a mentor community account. I am using my university email but it says
    Email Address Restrictions
    Please provide a company or university related email address to request a Mentor Communities account.
    If you have purchased Mentor software and do not have a company related email address, please obtain your Mentor Site ID and request a Support Center login.
    If anyone on this site also happens to use Calibre, I would appreciate it if you could share any insight to my calibre problems
    thanks
  • pvinay96
    pvinay96 over 7 years ago
    Hi, I am facing the same problem, did you figure out a way to fix this?
  • CxD7
    CxD7 over 7 years ago in reply to pvinay96
    Need to set :
    MGC_FDI_OA_VERSION 22.50
    using either setenv or export
  • happybin
    happybin over 7 years ago in reply to CxD7
    Hi CxD7,Could you tell me how to set MGC_FDI_OA_VERSION 22.50 in detail?
    Andrew Beckett over 7 years ago in reply to happybin
    Not knowing anything about this specific variable (since it's a Mentor product, not a Cadence tool), I would just interpret the previous post as suggesting you should do either:
    # if using csh
    setenv MGC_FDI_OA_VERSION 22.50
    # if using bash/ksh
    export MGC_FDI_OA_VERSION=22.50
    before starting virtuoso.
