  3. Assura LVS Parameter Mismatch Error
  • Replies 14
  • Subscribers 136
  • Views 29614
tonyinbos
tonyinbos over 8 years ago
Hi All,
I'm using Virtuoso Layout XL 617 and Assura 415, with TSMC mixed-mode 130nm PDK.
I included a multi-fingered NMOS moscap into the layout, using the generated parameterized cell. The Cap has 5 fingers, W=L=20um for each, with top&bottom plate connection, and top poly contact head.
The cell looked like that above.
However, when running assura lvs, I got the following error:
Schematic Instance: C0 nmos1v
Layout Instance: avD10_1 N
w 2e-05 vs 0.0001 differs by 400%
Layout Instance is the merged result of: avD10_1 avD10_2 avD10_3 avD10_14
avD10_15
While clearly the device has five fingers totaling 100um, ASSURA says it's only 20um. It works only when just 1 finger is used. Is there an explanation to this weird behavior of ASSURA? Thank you very much. -Tony
  • MADag
    MADag over 6 years ago in reply to tonyinbos
    Hi Tony,
    Thank you for turning me back.
    I checked LVS with a schematic&layout with only the inductor. Still, it's problematic. But I would like to mention couple of strange things about this LVS issue.
    1) For example, if I change the parameters of inductor (both in schematic and layout) I might get clear LVS result. As I mentioned in my previous post, inductor spacing was 4 um (which is max allowed for spacing). Interestingly, when I change another parameter of inductor, this spacing value could jump up to 4.04 um, which is higher than the max, automatically and Virtuoso doesn't force it to be 4 um. If I attempt to change spacing to 4.04 um manually without changing the other parameter, Virtuoso doesn't allow me. And when it is 4.04 um, I am able to pass LVS test.
    2) Without changing anything else, when I intentionally change pin labels to 'drawing(drw)' purpose (not 'text(tt)' purpose), I got a 'Pin Mismatch' error, which is as expected. But I don't get a parameter mismatch error while nothing is different with the previous case.
    3) One of my labmates was using the same pdk. He was getting this strange 'parameter mismatch error', too. He updated the pdk and used ' CDB to OpenAccess Translator ' ( one of the toolboxes of Virtuoso ) and converted his  cds.lib a nd he passed LVS, without getting errors but warnings. I followed the same method and it didn't work for me.
    4) In this parameter mismatch error, I had said while actual spacing was 4 um, LVS report sees it ~1 um. I changed the spacing to 2 um (both in schematic&layout) and LVS report saw it ~0.5 um, this time.  Plus, I couldn't get what you mean here. Would you please explain it a bit?
    tonyinbos said:
    check off the error with the foundry (basically living with the error and waiving your rights to complain if the taped out chip didn't work, do allow for ample time to communicate!)
    Kind regards, M.Ali
  • MADag
    MADag over 6 years ago in reply to MADag
    Hi Tony,
    I have somehow found a way. For anyone who has struggled with the same thing, this is thing that I did:
    I made the spacing 3.96 um instead of 4 um and LVS worked. I don't know but LVS seems not like integers. This might be a grid problem or something else.
    Kind regards,
    M.Ali
    Andrew Beckett over 6 years ago in reply to MADag
    This is unlikely to be a generic problem with "LVS" - it will be something to do with the specific rules for the specific foundry you're using - it might be an error in the rules or it might be a real issue - you really should check with the foundry as was suggested by Tony.
  • MADag
    MADag over 6 years ago in reply to Andrew Beckett
    Yes, we already have asked them and are waiting for the answer..
    M.Ali
