  3. error in checking lvs test with calibre tool
  • Views 19098
salar1991
salar1991 over 8 years ago
hi i'm trying to apply lvs test to the layout of my circuit that is a transimpedance amplifier which uses 4 spiral inductors .the problem is when i try to check lvs it gives me the  following errors :
no matching
".SUBCKT" statement for "SPIRAL_STD"
  source can not be read
what should i do to solve this i already read some forums that i added below but still didn't figure out  what to do. thanks in advance.
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/21424/for-lvs-how-to-include-initiate-a-spice-netlist-into-a-schematic
community.cadence.com/.../tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade
    Andrew Beckett over 8 years ago +1
    The second link is really related to including SPICE SUBCKTs for simulation purposes - and the first is how to include them in the CDL netlist in the first place. I suspect however what you need is a means…
    The second link is really related to including SPICE SUBCKTs for simulation purposes - and the first is how to include them in the CDL netlist in the first place. I suspect however what you need is a means to include a fixed CDL netlist (for some of the fixed cells) in the LVS. That's more of a Calibre question - which is a Siemens Mentor product - so this is not the best place to ask that.
  • salar1991
    salar1991 over 8 years ago in reply to Andrew Beckett
    My problem has been resolved . it was because of netlist file . in the lvs tool i went to inputs menu and then i selected netlist and then i added this address to the files /usr/local/IC614/tsmc13/techFile/Calibre_LVS/source_added.RF_12_25_FSG
    my cadence version is  6.14 .i hope this is helpfull for somebody who has the same error.
