  3. dynamic parameter in SpectreMDL
  • Views 17107
aarthymani
aarthymani over 8 years ago
    Basis: there is a need for me to change the temperature within the transient simulation.  I followed the post as linked below, and got it working in Spectre from ADE
   https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/10265/varying-the-temperature-in-a-transient-simulation
    Problem: as the data extraction is huge, I have been using spectremdl to run the simulation, now with the "temp" as dynamic parameter, there is no change in expected results, the changes are obvious in ADE simulation though.  I have extracted the netlist from the test bench that worked well in ADE.
   simple test case:
   the tran control reads:
             tran tran stop=1u param=temp param_vec=[0 27 315n 27 316n -20 416n -20 417n 100 517n 100 518n 40 618n 40] write="spectre.ic" writefinal="spectre.fc" annotate=status maxiters=5
   my spectremdl control file reads:
           t1 = temp @ 275n
           t2 = temp @ 375n
           t3  = temp @ 475n
but t1, t2, t3 all end up as same value. (T2=T3=T1=27)
So, I am wondering whether the option is supported in spectremdl? or am i missing anything here?
Thanks!
Aarthy
  • aarthymani
    Hi Everyone,
          It was my mistake, I missed the fact, "run tran" from spectremdl control file replace the tran from the netlist file.
    but I am still looking for any way to implement dynamic parameter (during tran simulation) in spectremdl tran statement. Any suggestions?
    Thanks!
    Aarthy
    Andrew Beckett over 8 years ago in reply to aarthymani
    No, that's not it. If you have an analysis with an instance name "tran" in the netlist, then "run tran" runs that analysis, with whatever parameters defined in the netlist (unless you override them in the MDL). The dynamic parameter is actually working - it's just that the temp variable in the MDL is not being updated when changed from the tran analysis.
    I filed CCR 1889737 for this. You might want to contact customer support and ask for a duplicate CCR to be filed so that it can be tracked against you as a customer (please mention this conversation and also the CCR number to avoid the AE duplicating work).
    Here's what I did:
        // -- start of netlist
        parameters period=100n tr=1n
        Vclk (clk 0) vsource type=pulse period=period width=period/2 val0=0 val1=1 rise=tr fall=tr
        R1 (clk op) resistor r=1k tc1=0.01
        C1 (op 0) capacitor c=1p
        save R1:res temp clk op
        // -- start of MDL
        alias measurement dostuff {
    	run tran
    	export real t1 = temp @ 275n
    	export real t2 = temp @ 375n
    	export real t3 = temp @ 475n
    	export real r1 = R1:res @ 275n
    	export real r2 = R1:res @ 375n
    	export real r3 = R1:res @ 475n
        run dostuff
        // -- end of MDL
  • aarthymani
    aarthymani over 8 years ago in reply to Andrew Beckett
       Thank you for the response and CCR.
      Actually, my circuit intention is not to measure the temperature as such. I was just using it to debug. And since the values are not updated and the actual values I was measuring also, didn't reflected the expected change. I doubted the functionality with SpectreMDL as I couldn't find anything in spectremdl documentation.
       From your reply, i understood it does work.
    Aarthy
