  3. Verilog A to symbol
  • Replies 19
  • Views 30398
Verilog A to symbol
Shobhitkareer
Shobhitkareer over 8 years ago
Im trying to make symbol using verilog A, the design is actually formed using 3 files; so in the beginning I have included the file using " 'include abd.vams" but while compling it seems that its to able read that file? One of the file is written in verilog-ams.
Am I missing any step?
Thank you in advance
    Andrew Beckett over 8 years ago in reply to Shobhitkareer +1
    Why are you including the VerilogA from other modules in another? I'd assumed (I suspect Dimitra did too) that these were some common `defines or something like that, rather than other module definitions…
    OK, I tried this - admittedly using IC617, but it should be the same in IC5141 (not sure why you need to use such an old version if this is something new... IC5141 came out in 2004, and the very last hotfix was in 2011)
    Anyway, what you have to do is set the env var that Dimitra mentioned early in this thread to include the directory where the parameters.vams file is. In my case I did:
    setenv CDS_VLOGA_INCLUDE $PWD/nano_model_35
    The I created three cellViews:
    • PCNFET_L1 : include files left as-is - so the entire content was as it was in the download from Stanford
    • PCNFET_L2 : remove the `include "PCNFET_L1.va" but add `include "parameters.vams" instead.
    • PCNFET : use the code from the file PCNFET_L3.va, but remove the `include "PCNFET_L2.va" and add `include "parameters.vams" instead
    Symbols then get created (and CDF) for each of the three cells, and if I instantiate PCNFET in a schematic and netlist to spectre in ADE, I get (at the bottom of the netlist):
    ahdl_include "/export/home/user/support/forum/nano/nanolib/PCNFET_L2/veriloga/veriloga.va"
    ahdl_include "/export/home/user/support/forum/nano/nanolib/PCNFET/veriloga/veriloga.va"
    ahdl_include "/export/home/user/support/forum/nano/nanolib/PCNFET_L1/veriloga/veriloga.va"
    So the netlister automatically includes all the right pieces into the spectre netlist.
    So as I said, you should not include the lower modules into the higher modules. There's no need.
  • Shobhitkareer
    Shobhitkareer over 8 years ago in reply to Andrew Beckett
    I know the version is so old that its frustrating to use, anyhow the error is still existing, when I initiate the instance in the schematic it doesnt show CDF parameters. But I still went on to get the netlist from spectre and attached is the error I got.
    This the same problem Im facing for a very long time.
    Thank you so much Andrew for such prompt replies and valuable guidance.
    Warmest Regards
    Shobhit
  • Shobhitkareer
    Shobhitkareer over 8 years ago in reply to Shobhitkareer
    Error found by spectre in `PCNFET', during circuit read-in.
    ERROR (SFE-23): "/home/v45960/shobhit/nano_model_35/CNFET/PCNFET/veriloga/veriloga.va" 94: The instance `XPCNFET_L2_edge' is referencing an undefined model or subcircuit, `PCNFET_L2'. Either include the file containing the definition of `PCNFET_L2', or define `PCNFET_L2' before running the simulation.
    ERROR (SFE-23): "/home/v45960/shobhit/nano_model_35/CNFET/PCNFET/veriloga/veriloga.va" 101: The instance `XPCNFET_L2_midd' is referencing an undefined model or subcircuit, `PCNFET_L2'. Either include the file containing the definition of `PCNFET_L2', or define `PCNFET_L2' before running the simulation.
    I tried this in IC5141 yesterday (admittedly I was using MMSIM11.1 rather than MMSIM7.2 that you were using, but I doubt that makes a difference) and it works fine. I'm using subversion 5.10.41.500.6.151).
    In terms of the CDF parameters being shown, this works fine - you just have to click on the "CDF Parameter of view" cyclic field to show them:
    Note that you should check your netlist (Simulation->Netlist->Display and see if you are getting the three ahdl_include lines). If you're not, maybe you're using an old subversion of IC5141 which had a bug? If so, what are you using (type getVersion(t) in the CIW to get the subversion and post it here). Have you removed the include of the lower level modules in the higher level modules?
  • Shobhitkareer
    even i thought the same and requested my department for an update but the problem persist
    Fullscreen andrew.txt Download
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 15.1.0.801.isr17 64bit -- 19 Apr 2017
    Copyright (C) 1989-2017 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: v45960   Host: razr-vm0-093   HostID: 10AC5D78   PID: 98237
    Memory  available: 7.4377 GB  physical: 12.4755 GB
    Linux   : Red Hat Enterprise Linux Workstation release 6.7 (Santiago)
    CPU Type: Intel(R) Xeon(R) CPU E7-8890 v2 @ 2.80GHz
    All processors running at 2793.3 MHz
            Socket: Processors
            0:       0
            2:       1
            4:       2
            6:       3
    System load averages (1min, 5min, 15min) : 3.8 %, 1.5 %, 0.2 %
    This is a virtual machine
    Simulating `input.scs' on razr-vm0-093 at 11:43:35 AM, Sat May 12, 2018 (process id: 98237).
    Current working directory: /home/v45960/simulation/CNFET/1/adexl/results/data/Interactive.0/1/CNFET:1:1/netlist
    Command line:
        /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/bin/spectre -64  \
            input.scs +escchars +log ../psf/spectre.out -format psfxl -raw  \
            ../psf +lqtimeout 900 -maxw 5 -maxn 5 -ahdllibdir  \
            /home/v45960/simulation/CNFET/1/adexl/results/data/Interactive.0/sharedData/CDS/ahdl/input.ahdlSimDB  \
            +logstatus
    Loading /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Loading /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
    Loading /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
    Loading /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
    Loading /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
    Reading file:  /home/v45960/simulation/CNFET/1/adexl/results/data/Interactive.0/1/CNFET:1:1/netlist/input.scs
    Reading file:  /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/spectre/etc/configs/spectre.cfg
    Reading file:  /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/spectre/etc/configs/mapsubckt.cfg
    Reading file:  /home/v45960/shobhit/nano_model_35/CNFET/PCNFET/veriloga/veriloga.va
    Reading file:  /home/v45960/shobhit/nano_model_35/disciplines.vams
    Reading file:  /home/v45960/shobhit/nano_model_35/parameters.vams
    Warning from spectre during AHDL read-in.
        WARNING (ASL-1): "/home/v45960/shobhit/nano_model_35/disciplines.vams" 95: The Verilog-A engine changed the units of Spectre quantity `Temp' from `C' to `K'. You might have a Verilog-A nature definition or a VHDL-AMS quantity definition of the same name.
    Time for NDB Parsing: CPU = 152.977 ms, elapsed = 418.635 ms.
    Time accumulated: CPU = 185.971 ms, elapsed = 418.651 ms.
    Peak resident memory used = 43.9 Mbytes.
    The CPU load for active processors is :
            Spectre  0 (27.5 %)      1 (19.0 %)      2 (35.7 %)      3 (73.2 %)
            Other
    Opening directory /home/v45960/simulation/CNFET/1/adexl/results/data/Interactive.0/sharedData/CDS/ahdl/input.ahdlSimDB (775)
    Created directory /home/v45960/simulation/CNFET/1/adexl/results/data/Interactive.0/sharedData/CDS/ahdl/input.ahdlSimDB/ff87d38f10e2724b96cac480ecd9f677.PCNFET.ahdlcmi/ (775)
    Created directory /home/v45960/simulation/CNFET/1/adexl/results/data/Interactive.0/sharedData/CDS/ahdl/input.ahdlSimDB/ff87d38f10e2724b96cac480ecd9f677.PCNFET.ahdlcmi/Linux-64/ (775)
    Compiling ahdlcmi module library.
    Finished compilation in 1.5 s (elapsed).
    Installed compiled interface for PCNFET.
    Reading link:  /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading file:  /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading link:  /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file:  /CMC/tools/cadence/MMSIM15.10.801_lnx86/tools.lnx86/spectre/etc/ahdl/constants.vams
    Time for Elaboration: CPU = 78.987 ms, elapsed = 1.58593 s.
    Time accumulated: CPU = 265.958 ms, elapsed = 2.00579 s.
    Peak resident memory used = 56.4 Mbytes.
    Aggregate audit (11:43:37 AM, Sat May 12, 2018):
    Time used: CPU = 266 ms, elapsed = 2.01 s, util. = 13.3%.
    Time spent in licensing: elapsed = 115 ms, percentage of total = 5.74%.
    Peak memory used = 56.6 Mbytes.
    Simulation started at: 11:43:35 AM, Sat May 12, 2018, ended at: 11:43:37 AM, Sat May 12, 2018, with elapsed time (wall clock): 2.01 s.
    spectre completes with 2 errors, 1 warning, and 0 notices.
    spectre terminated prematurely due to fatal error.
    version: sub-version  IC6.1.7-64b.500.14
    mmsim 15.1
    Im not including the lower levels.
    Please find the netlist generated. Still the ahdl are not being included.
    Regards
    shobhit
    Hi Shobhit,
    You didn't include the netlist. One thought I had was that maybe you've put veriloga in the Stop View List. This is on Setup->Environment (if not using a config view) or it's in the config view itself. You shouldn't have veriloga in the stop list, because that will stop the netlister descending into the hierarchy within the veriloga view, which would omit the ahdl_include for the lower levels.
    You need it in the switch list (so that it switches into the veriloga views), but not in the stop list.
    Hopefully that's it?
  • Shobhitkareer
    Yup I think that was the error, although when I opened it, verilogA wasn't in the stop list.
    However now its working.
    Thank you so much for your valuable time and for your constant efforts.
    Warmest regards
    shobhit kareer
  • Shobhitkareer
    I know its against forum rules, but I think this question will make more sense here. Please excuse this time.
    But if I have to do monte carlo simulation in this file how should I include the cds_inherited_parameter function, should it be in all the three file for the same parameter or including cds parameter in file L1 will be sufficient?
    Thank you
    warmest regards
    shobhit
    I would expect it would be in PCNFET rather than PCNFET_L1, but then again you didn't say what it is you're planning to statistically vary. The example (as you posted it before) had all instance parameters, whereas in this case you'd need at least one global parameter (which ends up being locally varied for mismatch) which is used within the model somewhere. See this article on how to define the parameters within a VerilogA model for Monte Carlo. Perhaps if you explained what you planned to vary, it would be easier to answer?
    Oh, and it would have been better to create a new thread and include a link to the original thread. This thread is already very long and so pity the poor reader who searches and finds this thread for (say) the monte carlo issue and then has to thread through the massive history above...
