  3. Is there a method for simulating a circuit with varying...
  • Views 15180
Is there a method for simulating a circuit with varying temperature?
funfet
funfet over 8 years ago
I wanted to know if there was a method for varying the temperature with time. How might one go about doing this?
Thank you
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    Hi Paul,
    You can use the 'Dynamic Parameter' in the tran analysis. You haven't mentioned if you are running Spectre in standalone or through ADE. To find out how to use the 'Dynamic Parameter':
    - If you run the simulations in standalone, look for 'Dynamic Parameters during Transient Analysis' in Spectre Circuit Simulator Reference documentation. (I'm adding the links in case you have access to the support site)
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=spectreref.xml&title=Spectre%20Circuit%20Simulator%20Reference%20--%203%20-%20Transient%20Analysis%20(tran)&hash=1063371&c_version=17.1&sq=005d0000002mxbiAAA_20185484341345&path=spectreref/spectreref17.1/chap3.html#1063371
    -If you run the simulations through ADE, look for 'dynamic parameters' in transient analysis section in Virtuoso Analog Design Environment L User Guide:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=anasimhelp.xml&title=Virtuoso%20Analog%20Design%20Environment%20L%20User%20Guide%20--%204%20-%20Setting%20Up%20an%20Analysis&hash=1019472&c_version=IC6.1.7&sq=005d0000002mxbiAAA_2018548522234&path=anasimhelp/anasimhelpIC6.1.7/chap5.html#1019472
    Dimitra
  • funfet
    funfet over 8 years ago in reply to Dimitra Papazoglou
    I got it to work, thank you.
