  3. Generate LEF file through Script
  • Views 17998
Ishant Anand
Ishant Anand over 8 years ago
I  have the GDS file of the layout. Is their any way to get the LEF file of the design through command line or script?
    Yes, this can be done with the Abstract Generator (the tool is called "abstract"). It can be run both interactively and in batch mode once you've set up how you need to recognise the pins and extract connectivity etc. There is a Rapid Adoption Kit on Cadence Online Support for this: Abstract Generator
  • Ishant Anand
    Ishant Anand over 8 years ago in reply to Andrew Beckett
    Sir, When i clicked on the link provided by you. It took me to the page to login and was asking my host ID. When i entered it, it still not allowing me to view the page. I would be very grateful if you could paste the solution here.
    Andrew Beckett over 8 years ago in reply to Ishant Anand
    I can't do that. For a couple of reasons:
    1. Our rapid adoption kits need a "click through" license agreement where you acknowledge the limitations on how you're allowed to use it
    2. It's too big to post here
    The documentation on abstract generator is included in the Help in Virtuoso - you should be able to find the manual from cdnshelp.
    Also, to log into the support site, you need to register first - using your login from the community forums is not sufficient. If you're from an academic institution, then you may need to go via your nominated professor, or if in Europe and using Europractice you may need to contact them for help with signing up. For maintained customers though, you typically just need the hostid of your license server to register on support.cadence.com
