  3. Schematic editor bus naming and connections questions.
  • Replies 7
  • Views 25141
mhkvy4
mhkvy4 over 8 years ago
I have 2 questions about instantiating multiple instances, the multiplier parameter and bus naming conventions in the Schematic editor. If I want to connect 4 MOSFETs( in parallel), in series, with another set of parallel MOSFETs like in figure A, do I do it using figure B or figure C. (I think it is figure B). If I do instantiate four MOSFETs like in figure 3, for both the top and bottom set, and if I make the connecting net a bus of width 4 bits then I think I get figure D.
1)So if I have this right figure A and B are the same, D and C are the same. Is this wrong?
2) if i want to declare an array of say 128 identical series resistors, how do I go about it?
Do I have to make the nets on either side a bus of 128 bits and instantiate resistors with R<127:0>? How do I go about declaring an array of identical parallel resistors? I am guessing for a parallel array I don't make the nets on either side of the R<127:0> into 128 bit buses.
  • Marc Heise
    Marc Heise over 8 years ago +1
    Hi, the m parameter is a model parameter, so there might be difference between having four separate devices and one device multiplied by 4 in the model card. Think along shared S/D areas and their cap…
    Andrew Beckett over 8 years ago in reply to Marc Heise +1
    Marc Heise said: the m parameter is a model parameter, so there might be difference between having four separate devices and one device multiplied by 4 in the model card. Think along shared S/D areas and…
    Andrew Beckett over 8 years ago in reply to mhkvy4 +1
    For a parallel resistor, better to use m if you can because it's better for the simulator, but if you did want to do it, then it would be like the bottom resistor in the picture below. The top resistor…
  • Marc Heise
    the m parameter is a model parameter, so there might be difference between having four separate devices and one device multiplied by 4 in the model card. Think along shared S/D areas and their cap values.  C and D are identical, yes.
    For series resistor arrays there is the s-parameter which we support. I don't know if your PDK supports this.  As  workaround you can  use the iterated instance method for series connection as well by defining kind of a loop:
    Expression  on the input net:  IN, internal<127:1>
    Device: RES<128:1>
    Expression on the output net: internal<127:1>, OUT
    IN - RES<128> - internal<127> - RES<127> .........RES<1> -  OUT
    Very useful for any kind of chains. (inverter delay line or ringos), just make sure your layout people are aware of that technique. ;)
    If you want them to be parallel, just connect the array to only one net on each side, if you declare a bus, the devices will be separated.
    Kind regards,
    MMarc
    One small tweak to what Marc said. A==B and C==D, but all four should be electrically equivalent. The m-factor is handled within the model code, but it should be (unless there's a bug) exactly equivalent to having m devices in parallel. It's more efficient from a simulation perspective, which is why APS (not Spectre, but it is done with APS) collapses parallel devices into a m-factor instead. Note that topologically B and D are different (and hence you might think that A and C are different), but since the middle nodes between the transistors are at the same potential, it doesn't matter electrically if they are physically connected or not. However, if they are separate devices, it's more work for the simulator as there are more nodes, and more equations to be solved - but the end result should be the same (within numerical tolerances).
    So there should not be a difference (other than a small possibility of a numerical difference in the simulator caused by the fact that the matrices are slightly different in the two cases).
  • mhkvy4
    mhkvy4 over 8 years ago in reply to Andrew Beckett
    Thanks for the reply. I just wanted to know if issues would arise during LVS even if they are electrically equivalent.
  • mhkvy4
    mhkvy4 over 8 years ago in reply to Marc Heise
    Thanks for the reply Marc.
    Just wanted to make sure that I am understanding you right. If I wanted to declare an array of 128 parallel resistors then I should declare it as  IN - RES <128:1> -OUT
    where IN and OUT are the net names on either side.
  • mhkvy4
    Just also wanted to say that along with the m parameter, the PDK I am using also has ng as a CDF parameter option. I am guessing that m just instantiates multiple parallel devices while ng instantiates multiple parallel devices with shared S and D like you mention.
    For a parallel resistor, better to use m if you can because it's better for the simulator, but if you did want to do it, then it would be like the bottom resistor in the picture below. The top resistor shows a series-connected resistor chain.
  • mhkvy4
    Thanks a lot Andrew. This was a big help.
