  3. ade assembler output expression plot by matlab
  • Views 17637
rfham
rfham over 8 years ago
hi,
i wrote one file which contents is "save *:all" and simulate the dc analysis, all the mosfet dc parameters have been saved, i set the outputs expression and for example, getData("NM0:ids"? result "dc"), i want to plot the current ids from matlab, then i open matlab from toobar, i can got the adeInfo in the workspace, how to plot output expression like this? thanks a lot.
    If it's just a dc operating point, there's no need for the save statement - it would be:
    getData('NM0:ids','result','dcOpInfo-info')
    If it's a DC sweep, then
    getData('I0.M3:ids','result','dc-dc')
    By the way, there's no need to use an include file - you can save results (not with *, but for specific instances) using the Probe->OP Parameters in the ADE Assembler/Explorer Outputs.
    Note that you can see the result names for getData by just giving the first argument, and it will return a list of the available output databases.
  • rfham
    rfham over 8 years ago in reply to Andrew Beckett
    thanks,Andrew, is there any doc or page for your useage of second getData, and if the output setup to expression, how to plot by matlab"?
    Andrew Beckett over 8 years ago in reply to rfham
    Well, 'help getData' gives a bit of a clue, but it's not that clear. I have an action to file some CCRs to get this improved to make it a bit more usable (on my to-do list).
    Not sure what you mean by the second half of your question?
  • rfham
    thanks, Andrew, maybe my question relates more details, cost so much time, appreciate for you comments,
    here is my screen, the first figure is interactive.17, and i set oppoint according to you advice. now without save_op.scs file, i can get my required information. then i open MATLAB by right click in the "result" tab.
    and with the help of matlab script. i can get information like figure two. but  variable "res", show false at "result" column.
    why?
    there are four folders in the interactive 17, what four folders used for? see figure in the bottom, thanks.
