  3. Assura QRC - Extracted View Error [ LBRCXM-644 ]
  • Views 2707
nokta
nokta over 8 years ago
While I was trying to make an extracted view, QRC gave me the error as below:
  Cadence Quantus QRC Extraction - 64-bit Parasitic Extractor - Version
15.1.1-s174 Tue Jul  7 21:42:47 PDT 2015
                                    Copyright 2015 Cadence Design Systems,
Inc.
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
 /cds/ASSURA414/tools.lnx86/assura/bin/rcxToDfII /home/nokta/work/cad/LVS6/invLVS/__qrc.rcx_cmd -t -f /home/nokta/work/cad/LVS6/invLVS/extview.tmp -w /home/nokta/work/cad/LVS6/invLVS
WARNING (LBRCXU-172): m2write fd 10, 1 tries, bytes -1 of 27, errno 9 Bad file descriptor
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: rcxToDfII_64 version av4.1:Production:dfII6.1.5-64b:IC6.1.5-64b.500.17 08/31/2015 04:54 (sjfql463) $
sub-version 4.1_USR4_HF25, integ signature 2015-08-28-0751
run on XXX.tr from /cds/ASSURA414/tools.lnx86/assura/bin/64bit/rcxToDfII on Wed Jul 18 19:49:42 2018
Loading tech rule set file : /home/nokta/work/cad/umc13nm/umc13mmrf/techRuleSets
Loading umc13mmrf/libInit.il ...
    Loading umc13mmrf/loadCxt.ile ... done!
    Loading context 'umc13mmrf' from library 'umc13mmrf' ... done!
    Loading context 'pdkUtils' from library 'umc13mmrf' ... done!
    Loading context 'Util' from library 'umc13mmrf' ... done!
    Loading context 'userUtil' from library 'umc13mmrf' ... done!
    Loading context 'oxf_cb' from library 'umc13mmrf' ... done!
    Loading umc13mmrf/libInitCustomExit.il ... done!
Loaded umc13mmrf/libInit.il successfully!
*WARNING* No library model for device "RSNWELL".
INFO (LBRCXU-114): Finished /cds/ASSURA414/tools.lnx86/assura/bin/rcxToDfII
 /cds/ASSURA414/tools.lnx86/assura/bin/avRCXxref /home/nokta/work/cad/LVS6/invLVS/__qrc.rcx_cmd -useRunName
@(#)$CDS: avRCXxref_64 version av4.1:Production:dfII6.1.5-64b:IC6.1.5-64b.500.17 08/31/2015 04:50 (sjfql463) $
run on XXX.edu.tr at Wed Jul 18 19:49:43 2018
Reading rsf
INFO (LBRCXU-114): Finished /cds/ASSURA414/tools.lnx86/assura/bin/avRCXxref
INFO (LBRCXM-642): Constructing the RCX run script
/cds/EXT151/tools.lnx86/extraction/bin/64bit//capgen: error while loading shared libraries: libtermcap.so.2: cannot open shared object file: No such file or directory
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
 /cds/EXT151/tools.lnx86/extraction/bin/64bit//capgen -techdir /home/nokta/work/cad/umc13nm/umc13mmrf/LPE -lvs /home/nokta/work/cad/LVS6/invLVS.xcn -p2lvs /home/nokta/work/cad/umc13nm/umc13mmrf/LPE/p2lvsfile -reseqn -sw3d -length_units meters -blocking RFSYMBOL,DIFF_diel,PSD_C,PLY_C,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C,MMCBP_C,MMCTP_C -res_blocking RFSYMBOL,ply,ME1,ME2,ME3,ME4,ME5,ME6,ME7,ME8,MMCBP,MMCTP -p PLY_C,Allgates,PSD_C -cap_unit 1 -blocking CMMC,MMCBP_C,MMCTP_C -blocking MOMVP1_MM_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOMVP1_MM_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOMVP2_MM_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOMVP2_MM_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_SY_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_SY_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_ASY_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_ASY_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C /home/nokta/work/cad/LVS6/invLVS
Forking:  /cds/EXT151/tools.lnx86/extraction/bin/64bit//capgen -techdir /home/nokta/work/cad/umc13nm/umc13mmrf/LPE -lvs /home/nokta/work/cad/LVS6/invLVS.xcn -p2lvs /home/nokta/work/cad/umc13nm/umc13mmrf/LPE/p2lvsfile -reseqn -sw3d -length_units meters -blocking RFSYMBOL,DIFF_diel,PSD_C,PLY_C,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C,MMCBP_C,MMCTP_C -res_blocking RFSYMBOL,ply,ME1,ME2,ME3,ME4,ME5,ME6,ME7,ME8,MMCBP,MMCTP -p PLY_C,Allgates,PSD_C -cap_unit 1 -blocking CMMC,MMCBP_C,MMCTP_C -blocking MOMVP1_MM_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOMVP1_MM_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOMVP2_MM_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOMVP2_MM_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_SY_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_SY_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_ASY_WEL,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C -blocking MOM_MESH_ASY_PSUB,ME1_C,ME2_C,ME3_C,ME4_C,ME5_C,ME6_C,ME7_C,ME8_C /home/nokta/work/cad/LVS6/invLVS
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  Quantus QRC terminated abnormally  *****
Also, I checked CIW but there was no addtional error. Do you have any suggestion about it?
  • mschw
    mschw over 8 years ago
    I once had a similar error. The solution I found here worked for me.
    Kind regards,
    Matthias
