  3. vpwlf error:Syntax error in waveform file `/home/users/pratike...
  • Views 1871
vpwlf error:Syntax error in waveform file `/home/users/pratike/data_interp_msb2.xlsx' at line 23
pratike
pratike over 7 years ago
   I'm trying to load .xlsx file using vpwlf. My file contains strictly increasing data,
still it gives error as : "Syntax error in waveform file `/home/users/pratike/data_interp_msb2.xlsx' at line 23".
  I'm using Virtuoso version IC6.1.7-64b.500.11
Below is portion of my data in file:
(My data contain only column 2nd and 3rd, 1st column (line no) is for your information to check line no)
1 0.0000000000 0
2 0.0000000004 0
3 0.0000000008 0
4 0.0000000012 0
5 0.0000000016 0
6 0.0000000020 0
7 0.0000000024 0
8 0.0000000028 0
9 0.0000000032 0
10 0.0000000036 0
11 0.0000000040 1
12 0.0000000044 1
13 0.0000000048 1
14 0.0000000052 1
15 0.0000000056 1
16 0.0000000060 1
17 0.0000000064 1
18 0.0000000068 1
19 0.0000000072 1
20 0.0000000076 1
21 0.0000000080 1
22 0.0000000084 1
23 0.0000000088 1
24 0.0000000092 1
25 0.0000000096 1
26 0.0000000100 1
27 0.0000000104 1
28 0.0000000108 1
29 0.0000000112 1
30 0.0000000116 1
Any idea ?
    You didn't mention which simulator you're using (or the version of the simulator, which is more important in this case than the Virtuoso version), but I'm guessing it's Spectre - looks like a Spectre error message.
    Assuming that the file is not just a text file with the suffix ".xlsx" but a Microsoft Excel spreadsheet, then that's not supported. I don't know why you think that you can use a spreadsheet with spectre's PWL source. It's not documented anywhere that you can do this - instead the source expects a text file with two columns of numbers (white space or comma separated). I tried with the content you provided above, and that works. With it in an Excel spreadsheet, I get a similar error to you (a different line number) - hardly surprising that it gives an error since the spreadsheet is a binary file.
  • pratike
    pratike over 7 years ago in reply to Andrew Beckett
    Actually I wanted my time data to be accurate upto 10 decimal places, tried it with .csv file, but it did not take any formatted data. That's why I go for spreadsheet. I didn't thought of .txt file.
    Now, I used .txt file and it works.
    Thank you so much Andrew for your help !
