  3. changing the location of netlist creation in loop
  • Views 15276
Suryansh Singh
Suryansh Singh over 7 years ago
Hello
Please refer to the link below:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/35371/creatnetlist-with-ocean-in-a-specific-directory,
I am trying to do a similar thing i.e. changing the location of netlist creation. I did set the "startup" env var before the simulator call but I have to run the createNetlist command multiple times and in different directories ( I am changing the directory as I want to change models and then simulate the netlist and do not want to overwrite). So, in that case, would it be a good idea to set this variable in every iteration?
Please guide me on this.
Also, I notice that if I interrupt my skill script(Ctrl+C) before it completes itself (since I have a lot of cases and it takes time) and then if I rerun it after making suitable changes, I get the following error :
 *Error* (Default-reader-method) generic:asiGetName class:list
Could you help me understand the reason for this?
Regards
Suryansh Singh
    Hi Suryansh,
    Setting it in each iteration is fine, but you have to call the simulator() function after changing it because otherwise it won't have an effect, as I stated in the other link.
    I wouldn't expect the error to occur if re-initialising the OCEAN session by calling simulator() - most likely the control-C has left the session state in an incomplete status and it's confused, but I'd expect doing simulator('spectre) again would fix it because it is like closing and re-opening ADE (you could try calling ocnCloseSession() too).
  • Suryansh Singh
    Suryansh Singh over 7 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for the reply. And yes, if I do ocnCLoseSession() I don't see the error.
    Regards
    Suryansh Singh
