  3. LVS issues with Hierarchy
  • Views 17121
aarthymani
aarthymani over 7 years ago
Hi All,
    I have big Analog, small digital block. Most of my design is custom based Analog, done with Virtuoso Schematic and Layout. the small digital blocks, i did digital flow, exported gds and verilog netlist, converted it into CDL for LVS comparison.
   When I tried to run LVS from Virtuoso using PVS , the first time it failed(Missing NMOS and PMOS)  So I had added N-Well surrounding the instance (excluding NMOS), and this time the LVS is clean.
   But the problem re-occurs when i instantiate this module in new cell, and try  to run LVS from that hierarchy.  I tried flat LVS run as well. Still same error.  My tool details as fllows.
Digital flow: Genus 16.10, Innovus 16.1
Virtuoso: 6.17, PVS 15.22
My digital cells Deep-N-Well and i have only single power domain.
Do anyone have any rough idea on where should i debug?  if need any details, let me know. I will try my level best to put as much as possible
Thanks!
Aarthy
    Hi Aarthy,
    Please contact customer support. Being able to see this will make debugging it much easier.
