  3. Reliability simulation takes huge memory
  • Subscribers 133
  • Views 15631
Nasser Arif
Nasser Arif over 7 years ago
Hi ,
We are running aging simulation with post layout netlist, and needs consume lot of memory(100GB) and hitting the queue limitation, I know that tools is saving lot of drain current for aging model generation.
I am trying to optimize the memory consumption, we are saving the voltage by probe statement
.PROBE V(ABC)
I am thinking to change it as
save ABC
will it affect memory consumption.? as probe will insert some probe instance
or if you can suggest anything to try.
Nasser
    Hi Nasser,
    I've not come across such behaviour before, so I suggest you contact customer support. I doubt this has anything to do with the probe (and I can't see why save would make it any better). Most likely the challenge is that the aging approach will need to create an updated aged model for each instance, and so you lose the benefits of model sharing and the memory consumption increases as a result of that. However, this is just a guess, and it would be better to work with customer support so that we can get more details of the precise nature of your circuit and simulation.
    Kind Regards,
  • Nasser Arif
    Nasser Arif over 7 years ago in reply to Andrew Beckett
    Thanks Andrew, Sure will conatct CDNS support for further help.
    Regarding save and PROBE statement, so far my understating is ,in probe statement tool insert some probe element, but not sure if "save" works in the same way.
    Please correct me if my understanding is wrong.
    Nasser
    Andrew Beckett over 7 years ago in reply to Nasser Arif
    Hi Nasser,
    As far as I know, .probe doesn't insert any element in the circuit. Even if it did, I doubt it would have significant impact on the memory usage of the simulation.
  • Nasser Arif
    Thanks Andrew for correcting me.
    Nasser
