  3. How to load bare virtuoso?
  • Views 17351
fatcat1206
fatcat1206 over 7 years ago
Hi Everyone
I remember there is an option during the virtuoso launching to skip loading the in-house wrapper and content inside the .cdsinit* files.
Besides, it's also possible to skip loading such content when launching ADEXL simulations with icrp.
Can someone remind me about such setup?
Many thanks in advance.
Best Regards
Yi
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago
    Are you looking for 'virtuoso -nocdsinit'?
    Saloni
  • fatcat1206
    fatcat1206 over 7 years ago in reply to Saloni Chhabra
    Hi Saloni
    Thanks for your reply. It's the answer for my first question.
    With this option, it's much faster to launch the Virtuoso.
    I have tried to run ADEXL simulation under 'virtuoso -nocdsinit'.
    Unfortunately, it does not affect the icrp process. As in the Job log file, I can still see:
    "\o >> Loading settings from file .cdsinit in your home directory.<<"
    I remember I received an environment variable from Cadence AE to control this. Unfortunately, I cannot access my mail box after changing the job.
    Do you have any hint about it?
    Best Regards
    Yi
    Andrew Beckett over 7 years ago in reply to fatcat1206
    Hi Yi,
    This is the .cdsenv (suggest you put it in your home dir):
    adexl.icrpStartup binaryName string "virtuoso -nocdsinit"
    I won't suggest the envSetVal equivalent because if you're not loading your .cdsinit then it won't get loaded!
  • fatcat1206
    fatcat1206 over 7 years ago in reply to Andrew Beckett
    Hi Andrew
    Thank you for the reply.
    You are absolutely right, if I put it in my .cdsinit, then I must load my .cdsinit to make it effective.
    Most of the case, I will just type in the envSetVal(...) command directly in the CIW.
    Then I am kind of bring my Virtuoso in a debug mode, where ADEXL launching the simulation much faster.
    I have also been warned by Kai Schiller that when using this setting it may cause some simulation issue, if the model file is kind of processed by the in-house wrapper.
    I will use this setup with caution.
    Best Regards
    Yi
