  3. Simulation for Ferroelectric Capacitor (Based on VerilogA...
  • Views 17848
Simulation for Ferroelectric Capacitor (Based on VerilogA model) for C-V curve
Piash
Piash over 7 years ago
I have created a Ferroelectric Varactor model using VerilogA. Now, I wan to simulate the C-V curve. I have added a voltage source with the varactor with AC magnitude of 1. Now for ac analysis, I swept across dc voltage along which I want to plot the capacitance. I have selected current to be plotted of my device. Now how can I convert it to capacitance? At what frequency should i put for analysis frequency poit? Can anyone help to setup in ADE to simulate C-V curve?
I am using Cadence Virtuoso with spectre simulator.
Version: ICADV12.3-64b.500.21
I have attached my ADE and testbench screenshot.
    The same question has been asked (presumably by you, since the pictures look rather similar) and are being answered over on the Designer's Guide forum - here: http://www.designers-guide.org/Forum/YaBB.pl?num=1543487056
  • Piash
    Piash over 7 years ago in reply to Andrew Beckett
    Yeah... I found out the problem it was in my verilogA code of unit conversion problem which was stupid to find out. But anyway, I figured it out Thanks. Should I delete the post here?
    Andrew Beckett over 7 years ago in reply to Piash
    No - best to leave it in case anyone else has a related issue or is interested - they can then follow the links over to the Designer's Guide site.
